Question about Durabrand PDV-705 Portable DVD Player
Dvds dont work
My portable dvd player does not recognize dvd's. It will play cd's and regular disks that have movie footage on them that arent dvds but when you put in a dvd it either says loading and then stops by itself or it says error no disk. Do you think there is somthing i can change to make it work or an inner problem that has to get fixed by an expert?
  • 362 Answers
Have you tried a cleaning disk and make sure the movie disks have no finger prints on them that will stop it from loading.
Posted on Dec 12, 2007
It depends how you burn movies (for example). If you burned as data disc, it's probably won't play it. Make sure you burn movies as DVD format.
May 19, 2012 | Samsung portable dvd player DVD-L200 User...
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
The part that reads the DVDs is defective. I would suggest to try cleaning it using a lens cleaner, hopefully that works.
If the cleaning does not work, it might just be cheaper to buy a new one instead of repairing this one.
May 20, 2008 | Mintek MDP-1760 Portable DVD Player
No picture, only sounds when playing DVD
The issue might be that you could be missing some codes to play the dvds.
First i want to uninstall all the codecs from the control panel - add/remove programs.
Then download the latest vesion of klite codec pack with the player.
The link is :
Install this by selecting "lots of stuff" with the player.
Then play your DVD, it will work fine.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Haier PDVD10 Portable DVD Player
Won't play some DVDs
ya try cd lens cleaner ok they sell at store its a cd with litte brushes on it cleans lazor ok thx nick
Feb 11, 2008 | Mintek MDP-1010 Portable DVD Player
My Insignia 8" Portable dvd player does not detect dvd!
Try playing a regular CD first and take it out if it played. Then put the DVD and it will play fine because the player just realign its lense. Hope it will help
Jun 17, 2007 | Insignia PD10135 Portable DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
Mar 31, 2007 | NAD C541 CD Player
Durabrand PDV-705 Portable DVD Player Logo
216 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
