Question about ViewSonic VX2235wm LCD Monitor
Hi have a Viewsonic 22 VX2245wm. When it was
Hi I have a Viewsonic 22 VX2245wm. When it was on there was a blue light to indicate power on, then when off it turned to red. Now it just flashes between the 2 colours
any idea what is wrong?
cheers Mike
  • 1,684 Answers
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
Viewsonic VX2245WM blue light turns on indicating power, but screen is black, capacitors look fine
If the capacitors look good then the most common cause of black screen on this unit is the MOSfet driver chips and the 4amp fuse. The driver chips are the little black squares at the top of the board with 8 legs. They are part number AOP605 The 4amp fuse is located on the bottom of the board and usually has a "W" printed on it. The fuse is very small, about the size of a grain of rice.
The repair would require replacing both chips and the fuse. The parts are available here: http://www.ccl-la.com/catalog/index.php?cPath=39
Apr 16, 2013 | ViewSonic VX2245WM LCD Monitor
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
Blue power light is on but screen remains black
Common problem with 2235/2245 is failed capacitors in the power supply/inverter board combination. You need to get the P/N and names of the board since there may be more than one version of the assembly for the same model.
When you get the information, then you can check here: http://www.lcdparts.net
Post back so it may help other people also.
Apr 09, 2010 | ViewSonic VX2235WM Monitor
Viewsonic vx2245WM has no picture when I plug it in. I tried DVI and VGA.The little blue light comes on indicating theres power? But I have no image. I got this used from a friend. It didnt come with any...
Capacitors inthe power supply will be the first thing to check, look for caps with bulging tops or seals, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
The porblem can also eb in the onverter circuits, or bad lamps. Post back what you find so we can guide you further.
Mar 11, 2010 | ViewSonic VX2245WM LCD Monitor
I have a Viewsonic VX2245wm or VS11349, Works and then it goes black for 2 to 4 sec then runs for 10 to 15 min and goes black
Look at the power supply section for bad caps first, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, it can also be caused by bad inverter circuits or bad lamps.
Feb 20, 2010 | ViewSonic VX2245WM LCD Monitor
I have power going to my Viewsonic VX2245wm but no image
You need to check the internal power supply to see if your capacitors have popped. Even though it may show power, the portion of the power supply that powers the LCD itself may have been damaged ::
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/?action=view&current=DSCF1718.jpg
Jan 10, 2010 | ViewSonic VX2245WM LCD Monitor
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
394 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
