Question about Sony Ericsson K800i Cellular Phone
No screen when i turn my k800i there is only a image where there is not ment to be one and the is no icons or no menu or anythink
My screen has caution screen image may appear reversed how do I fix it
It's showing the rear camera display, but you don't have a camera connected.
Press the "home" button, then press the rear camera icon on the display. This will stop the display from defaulting to the rear camera input. Then go into the settings menu, find the rear camera setting and turn off the camera. That should disable the camera icon on the home menu.
Aug 28, 2015 | Car Audio & Video
I want to change main menu icons will u guide me?
You should change the theme of your phone, this will automatically change your main menu icon...
Apr 21, 2011 | Sony Ericsson K800i Cellular Phone
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • From the Menu screen, select Settings
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Dec 31, 2009 | Sony Ericsson K800i Cellular Phone
Well it says its unlock !!
Menu on it's own doesn't work - it will take you to the "emergency call" screen. You need to press "menu" + "L" to bypass the activation screen.
Jul 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
How do I set the start image? I've tried following the menu commands, but when I select "Start Image," my options are the logo, "off," and then a black box with a question mark. I've selected it, and it...
After going through the menu and choosing user image, view the picture you would like to set as your start image. Press the button with the E on it that is underneath the zoom button. The screen should then show four images across the top, say the word "RESIZE" under that, and have the numbers 7,5,3,and 1 down the left hand side of the display. Below the number one there is an icon of a person and a camera. Scroll down to that icon and press the OK button. Your start image should now be chosen. Turn you camera off and power it back up to see if it worked. Hope this helped.
Mar 07, 2009 | Samsung L200 Digital Camera
K800i
hi revodev
can u explain this icon you have ?
is it the bluetooth icon or mised call's one etc can you post back what the icon looks like,
riz.
Jul 10, 2008 | Sony Ericsson K800i Cellular Phone
PROFILES icon missing and an ERROR message is shown at start up
try giving the restore factory settings option(or reset option) ....
(it will ask for the security code or password) ...
after giving this all of your problem will be solved ...
there is very less chance if you still persist any problem then just may use of warranty as it is new one .....
any doubts reply me
i am always here to assist you
thank you
bye
Jun 16, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
