Question about Thomson Lyra PDP2842U MP3 Player
Computer doesnt recognise when connected
I have installed all of the software for this player, but when i connect it, it doesnt show up on the computer.
If i look at device manager it says that "This device cannot start. (Code 10)"
i have gone through the troubleshooter and tested my usb ports and the device is on and everything - so just dont konw what the trouble could be!
Can anyone help please???
  • weemisssunsh Nov 24, 2007
    Thanks, just installed wmp11 and now it is recognised without the exclamation mark in device manager for about 20seconds (it says there are no drivers installed then) and then it reverts back to having an exclamation mark and gives the same message as before..
    Slightly better, but still not able to put any music onto it!
    Thanks for trying though!
  • sexylatinapr Jan 24, 2009
    i connect the device to my computer but it shows up that the computer does not recognize it.
  • 626 Answers
Code 10 means it cannot find the drivers.
Most of the newest MP3 players are designed to run with Windows Media Player version 10 or higher, this contains all of the drivers necessary for installation and recognition.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 24, 2007
USB not connecting.
Well you need to install the driver/software of your player into computer, install them from the cd comes with your player. If you don't have the cd then please follow the below link to download the driver/software -
(First connect your player to computer and then install the driver/software after downloading. If your computer ask to restart then restart them)
Good Luck!!
Mar 31, 2010 | Samsung YP-T10 Digital Media Player
Sony K610i Will not sync with my computer
Please ensure that all drivers are installed. Check in device manager.
Right click on my computer and select properties. Then select the hardware tab and device manager in that section. If any drivers are not installed properly they will appear with a yellow exclamation mark. Reinstall these.
If all drivers are installed correctly check the contacts on the phone as sometimes the tend to get dirty and block the signal. also check if cable is faulty.
May 25, 2009 | Sony Ericsson K610i Cellular Phone
Hey ..
Its easy
Go to Control Panel-> add hardware then Stop here...
connect your payer
then press next -> yes i have already connected the hardware -> next->
In the installed hardware list go to the bottom one "Add a new hardware device".->next
Select "Search for and install the hardware automatically" ->next
after that in the hardware category select "portable device"
then just next next and ..
it will be done .....
Cheers .... VD from The VDCompany ..
Mar 25, 2009 | Samsung YP-Q1JEB/XEU Digital Media Player
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
When i put the usb in the computer it doesnt connect
I would suggest that first you make sure that your computer is updated with Service Pack 2 or 3, DirectX9 or higher, and Windows Media Player 10 or higher. To do this, I went to Start -- Control Panel -- Windows Update. Then downloaded and installed all updates as required.
Secondly, I downloaded the codec for the portable device. To do this I pluged the MP3 Player into the USB port (still not recognised), went to Start -- Control Panel -- Printers and Other Hardware -- Add Hardware and this prompted the Hardware wizard. Clicked "Next" and selected YP-U3 from the list. Then selected "Install Automatically" and Voila! The codec was downloaded and the portable was recognised.
Jan 08, 2009 | Samsung YP-U3 MP3 Player
I have a connecting question for the Samsung P2
use control panel, then "add hardware" look for P2 in the list, reinstall it.
Jul 11, 2008 | Samsung Yepp YP-P2 Digital Media Player
Phillips mp3 player
Connect the player to the power adaptor and connect to the PC.
On the player press and hold "Power" & "Vol +", this should reset the player.
Wait for PC to recognise player.
If this doesn't work try the following:
Connect the HDD6330 to the mains adaptor and the PC.
Before the computer has a chance to recognise the player, press "Power" and "Vol +" to reset the player.
As soon as the player resets (screen goes blank) press and hold "Vol -" until the PC recognises the player as a removable drive.
Try to access the player through "My Computer" as you would the main hard disk.
If the computer recognises the player, then it can be restored by copying the system files directly on to the player.
Feb 14, 2008 | Philips GoGear HDD6330 MP3 Player
Yellow triangle
Install and run Device Manager from the product CD.
Select the repair option, and follow the on-screen prompts.
If this doesn't work then it may be that the hard disk is faulty. There is an easy way to find out. The following procedure allows the player to connect to the PC as a removable drive. If the Pc reads the drive, then the drive is ok.
Connect the HDD1630 to the mains adaptor and the PC.
CLICKING HARD DISK is usually a sign of a problem with the hard disk. If this is the case it will have to be replaced.
The HDD16X0 series use a standard 6Gb Microdrive which are readily available, and much cheaper than the official Philips replacement. The new drive would need to be "Repaired" using the Philips Device Manager.
Nov 18, 2007 | Philips HDD1630 MP3 Player
I have some china made mp3
Make sure that you have installed the software the the mp3 player came with and that you have powered on the mp3 player once it is connected. If you want the Sansa e250 to show up in "My Computer" under removable devices, go to the main menu of the player software and go to Settings/USB Modes/ and change the mode to MSC (Mass Storage Class). Hope that helps.
Aug 17, 2007 | SanDisk Sansa e250 MP3 Player
Thomson Lyra PDP2842U MP3 Player Logo
213 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
