Washing Machines Logo
P
Paul Miller Posted on Mar 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sears washer Model 110-45644291 issue with the agitator. top load. will fill then sounds like a clutch not catching and the agitator won't move. pump works, drain is fine. what should I do?
pawnpower
Level 3:
Master:
  • Master 851 Answers
  • Posted on Mar 08, 2018
 pawnpower
Master
Level 3:
Master:
Answers
851
Questions
Helped
246842
Points
2332
You didn't say how old it is, - but likely the cost effective solution (if it is more than 5 years old) is : buy a new washer.
5 Related Answers
Anonymous
  • 641 Answers
  • Posted on Aug 06, 2007
SOURCE: washer will not agitate
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Anonymous
  • 5911 Answers
  • Posted on Jun 12, 2008
SOURCE: LSQ9520LQO Top loading washer
It sounds like you have a defective lid switch. This is a typical symptom when the washer stops when it gets to the rinse cycle and won't drain. You can check by opening and closing the washer lid and listening for a "clicking" noise as the lid switch activates. The switch is located on the right hand side of the wash tub opening and is activated by a plastic piece on the lid (called a lid strike) through a small hole. You also attempt to use a small screwdriver and push down on the lid switch contact through the hole to see if the switch will make contact. Typically the switch either comes loose, the lid strike breaks off, or the switch breaks. If you diagnose the problem and it turns out to be the switch, you can use the following link for instructions on how to replace it:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Replacement parts can be found at searspartsdirect.com. Just type in your model number and your part can be found under the "Top & Cabinet" heading on the next page as item 11 (part #3949247). The lid strike can be found under the same heading as item number 20 (part #358684).
NOTE: You do not have to drain the wash tub to replace the lid switch. The switch repair does not require you to move the washer. Let the washer to the work. With the switch replaced, the washer should drain on its own by placing it on the SPIN cycle. You can also make a by-pass by using the old lid switch. With the old lid switch removed, simply cut the white plug off the end of the switch, leaving about an inch or two of wire (This is the connector that's attached to the SWITCH, NOT the timer!). Cut the middle wire flush and splice the two remaining wires. You now have a by-pass that you can connect to the timer plug to drain the washer. This will also enable you to use the washer until your part arrives. CAUTION: It is not recommended to leave the washer in this state, as the tub will no longer stop when the lid is opened. You will have to stop it by manually pushing the timer in, or wait until the timer completes the full wash cycle.
If you do not wish to order parts online, use the part numbers provided and take to your local applaince parts retailer. I hope you find this information helpful. Please post back if you have any questions, or require further assistance.
A
Anonymous
  • Posted on Jul 27, 2008
SOURCE: Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jan 11, 2010
SOURCE: I have a Kenmore Top load Washer won't drain
You must have a lid switch problem . I have a page I compiled which features lid switch replacement: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "you were right thank you very much."
Anonymous
  • 43501 Answers
  • Posted on Jun 12, 2010
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Agitator catches sporadically. Sounds like
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the Whirlpool / Kenmore Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
This points to one of two areas.
The first is the splines in the agitators worn or damaged:
See the following for how to remove the agitators and check the splines.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to remove the cabinet, motor, transmission tub etc.
If the splines on the agitators are OK, the problem could be a slipping clutch.
Remove the cabinet, pump, motor and transmission (you already have the agitators out) and check the clutch springs and bands.
If they are worn/damaged Sears has a replacement band kit for a lot less than a complete clutch.
My top load washer will not agitate or spin, but will fill and drain. The belt is fine and the agitator will move by moving the belt back and forth. What should I do next? Thanks
if you have aaccess to the belt already,
start the machine let it fill
then keeping an eye on the motor and the clutch underneath it, sounds like your clutch might be slipping..
you will notice immediately the motor will be spinnging but the clutch will not engage
ive included the part number
and phone number to call
AP2045377
1-800-477-7278
aplliancepartspros.com
runs about 120.00
but its a pretty easy repair especailly since you figured out how to open the cabinet
Kenmore 92587400... The dual action or top portion is not spinning
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92587400
I assume that you mean that the top agitator is not.
See the section of the Sears site for Agitator, Basket and Tub.
You'll see an item #5 "Clutch, Agitator". These are basically used to allow the top agitator to move only one way. If they are worn (which happens since they are plastic parts) the top agitator may not move either way.
There is also a part #6 "Agitator Auger" that screws into the main agitator shaft from the transmission. If this is loose, the top agitator may not move either.
Both of these are easy to check and repair.
Washing machine will fill with water, but won't articulate
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
I assume that you mean after filling, it won't begin the agitate cycle.
If you can hear the motor but the agitator won't move, it could be the "motor coupling". (See the motor section of the Sears site. This coupling is a fail safe between the motor and transmission. If the plastic prongs break, or the rubber center piece wears out, the transmission cannot agitate the washer.
If you can't hear the motor, it could be a timer problem.
Try to manually move the timer to a spin position and see if the motor / transmission move. If they do, it is most likely a timer.
This Kenmore Elite Top Load Washing machine has
This gets a little tricky.
It sounds as if, based upon the weight in the tub being reduced, the noise gets less. Something is pressing on something else due to the weight.
If you look at the gearcase parts section of the Sears site, you'll see parts called the agitate gear and agitate cam.
If the agitate cam wears (it's two plastic pieces) when the transmission moves to the spin cycle, the cam is supposed to lift the gear above it.
If it doesn't lift the gear high enough, you'll hear loud gear noise. This may lessen as the washer pumps water out and there is less weight on the spring.
We had the same problem with a washer and found that by replacing the cams, the noise went away.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Is there a spin clutch adjustment on a kenmore older model washing machine
This assumes that your washer is a top loading unit.
There isn't a clutch adjustment on Kenmore / Whirlpool top loader, direct drive washers.
Sears does have a clutch rebuild kit however.
See the Sears site:
and enter your model number.
A list of sub-components should come up.
Click on the motor and clutch link and you should see parts for a complete clutch and the band and lining kit.
Replacing either requires removing the cabinet, agitators, pump, motor and transmission.
Then removing the clip that holds the clutch to the top of the transmission and either replacing the entire clutch or just the band and lining.
1helpful
Agitator moves slowly
* Inspect the agitator
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
* Inspect the pump coupling
Washer will not agitate
Top Sears Washing Machines Experts
john h
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
