Question about Garden
Redress the Teak
I have a Hampton Bay Teak Dining Set. There was a product recommended to reoil the teak---What was it?
    President:
  • 1,486 Answers
Bees wax.Is a good one for teak.Should get it from a good hard wear store.
Posted on Aug 01, 2009
How do I remove black water stains from normally oiled teak wood?
well 1st you need to determine what stains are made from ? if there a food stain then there most likely made from a grease of some sort , if this is so then denatured alcohol will take them off (with a bit of rubbing ) if there a rust or mildew stain then you'll have to use something stronger like muriatic acid (diluted w water 50/50) also note never add water to acid but instead add acid to water (yes it makes a huge difference) , this is dangerous stuff and all safe precautions need to be taken with it , this will also require all the teak oil finish to be reapplied after acid is neutralized with say baking soda and water (paste) and dried in air as this rough chemical will remove all the woods natural oils
while teak is a nice wood to have (beautiful looking) when something like this happens to it , it sure is a expensive wood to maintain
Oct 30, 2015 | Home
Teak nostalgia 680 manual - no sound on mine? Can I get a download manual?
Hi , the link below is for the website to obtain support for your device, as requested
Jun 19, 2015 | Audio Players & Recorders
I need a schematic for Teak reel to reel tape recorder model AR 40S
It comes with the service manual. Stereomanuals.com is the best place to buy them. The E bay manuals are usually junk unless you get an original with all the pages.
Mar 06, 2015 | Audio Players & Recorders
Is teak oil sticky like paint when applied to wood
yes it will be especially in sunlight !
are you doing the teak decking ?
i only did this once and never again because became sticky and marked the inside carpets ! only clean teak decking with the special cleaner then apply brightner fluid !
Jul 30, 2014 | Star Brite Premium Teak Oil
We removed all the wood trimming/doors inside our Catalina 30 sailboat. We want to do a clean/revive type job on it. The wood is teak. How do we proceed?
if the teak is bare teak --- a light sanding with a sanding block should be good and then follow that with a good rub down of teak oil ( sea-fin teak oil is a good brand ).
if the teak is finished teak --- and you want to remove the old finish and sand out any stains(?) then you will need to use a more aggressive sand paper and finish off with a lighter sand paper,, clean up with acetone, use a good tack cloth and start applying varnish -- the best varnish that I have ever used is a brand called ' Epiphanes ' and you will either want to use a ' matte ' finish or a ' gloss /semi-gloss ' finish. personally I have found the 'matte ' finish to look better and it brings out the true beauty of the teak itself. ( make sure you follow the sanding instructions between coats as this will give you a nice smooth and sharp look ).
enjoy the water ---
c...
Jan 04, 2011 | Boating
Need to purchase battery pack BP-R1 for Teac R1 radio
Teak does no longer carry this specialty item. They do not stand behind their product and deserve to be bypassed in the future.
Oct 07, 2010 | Teac R1 FM/AM Radio
Dampness atound casing on frezzer
inside the refrigerator is a small switch which has energy saver and another side that differs with brands put the switch on the other dide (not energy saver) and this will energise a mullion heater which runs around the frame under the plastic mouldings. what causes the dampness? the difference in temperature between the fefrigerator and room temperature
Feb 05, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Hampton Bay Ceiling Fan
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 01, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
