J
Jean-Paul Te Kura Posted on Mar 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the clock on my Panasonic SA-Ak270 mini stereo
Level 3:
  • Panasonic Master 6,688 Answers
  • Posted on Mar 08, 2018
Cindy  Wells
Panasonic Master
Level 3:
Answers
6688
Questions
0
Helped
3529931
Points
21744
The main unit is the SA-AK270. The entire mini-system is called the SC-AK270. The manual is available on the Panasonic support site: https://www.panasonic.com/au/support/manual-download/audio/hi-fi/sc-ak270.html . You do need to accept the Panasonic terms of use to download the manual. The check box is below the box with the Manual description and View link. The clock setting procedure is shown on page 14 (with the remote). The pictures of the remote control and main unit buttons are on pages 8-9 of the manual.
With the remote, press the Clock/Timer button until the Display is showing the time. Press Skip Back/Rewind or Skip Forward/Fast Forward within 8 seconds of pressing Clock/Timer to set the hour. Press Clock/Timer again and use the same Rewind/Fast Forward buttons to set the minutes. Note: the SC-AK270 uses a 24-hour clock.
You can also do this by starting with the Display button on the main unit. Then use the Skip Back/Rew and Skip Forward/Fast Forward buttons on either side of the Manual Eq button.
I hope this helps.
5 Related Answers
ravichetty
RAVI CHETTY
  • 158 Answers
  • Posted on Jul 31, 2009
SOURCE: Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Willy83
  • 4 Answers
  • Posted on Aug 10, 2009
SOURCE: Panasonic SA-AK27 Bookshelf Stereo - Setting The Clock
Have you put on the eco mode? try this: power on the unit, click on the eco button, until the unit will display "normal"
Anonymous
  • 189 Answers
  • Posted on May 12, 2010
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Anonymous
  • 4234 Answers
  • Posted on Jul 07, 2010
SOURCE: I have a Panasonic SA-AK640 mini stereo system and
The CD loading mechanism is out of time and has not reset correctly. This cannot be reset. The loading mechanism must be dis-asembled and rebuilt. This is not a DYI repair. Any Panasonic service center can repair this for you.
Dan
Anonymous
  • Posted on Aug 17, 2010
SOURCE: User manual
Panasonic SAPM37MD..CAN USB ATTATC THE COMPUTER TO IT??
3answers
Panasonic SA-AK47 5 disc CD system. The volume button not working?
Service Manual, you need to test and/or replace.
Panasonic SA-AK47 Service Manual - ManualsLib
https://www.manualslib.com > manual > Panasonic-Sa-...
View and Download Panasonic SA-AK47 service manual online. SA-AK47 stereo system pdf manual download. Also for: Sb-ak47.
1helpful
Panasonic SA-VK760 Compact DVD Stereo. When I plugged in, the stand by light comes on, but machine doesn't turn on?
Question edited for clarity, add maker.
Question moved from Washing Machines category.
It needs professional repair unless you have a background in component electronics.
https://www.google.com/search?q=sa-vk960
How do I hookup speaker wires to my sa ak57 Panasonic stereo?
The SA-AK57 is the center of the SC-AK57 mini stereo home theater system. The included speakers have color coded wiring for the front speakers. One speaker connects to the red and black terminals on the SA-AK57; the other speaker connects to the blue and grey terminals. Push on the top of the terminal levers and insert the bare copper wire into the opening. Then release the lever. The center, right and left speakers use a single RCA or banana-plug connection and plug straight into the jacks on the SA-AK57.
Panasonic has the manual for the SC-AK57 on the product page: https://shop.panasonic.com/support-only/SC-AK57.html . The current link to the manual is ftp://ftp.panasonic.com/audio/om/sc-ak57_en_om.pdf . See page 7 for the speaker wiring.
I hope this helps.
2helpful
2answers
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
1helpful
Hi, my Panasonic SA-AK270 wont work. When I plug it in the AC IN light comes on but nothing else will work when I try to turn it on! Anyone know what wrong?
The power transformer is likely the problem, usually the primary windings open causing complete loss of power on the display, to verify, the unit will need to be taken apart and tested.
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
How do i set the clock on my panasonic SA-PM35MD STEREO?
Press 'Clock' on the Remote Press Left Rev key, and Right FF key to tune time.
Panasonic sa-ak270 will not turn off and go into standby. is this a fault. it shuts down for 2 seconds then turns back on scrolling through all the programmes with red light illuminated. says goodbye then...
Hi, I have an SAAK410 and also a SAAK510. Both of them would restart after about 20 seconds untill I set the clock using the hand control. Both switch off correctly now. Hope this helps.
1helpful
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
