Question about Ricoh Aficio 1515MF All-In-One Laser Printer
What is the default IP on a Ricoh AF1515 MF ? It's not taking DHCP and the DeviceMonitor for Admin doesnt pick it up. The network cable works to my laptop.
I have discovered the button I was looking for. In the center, right above the keypad is a small button that reads [123]. This button opens up the menus you need to configure the printer, and the network interface - which is a add-on device. My next hassle is figuring out how to set up network scanning.
Posted on Jul 31, 2009
  • 79 Answers
Go to this link and download any manual you want for that model, otherwise you can always download "IP SCANNER" , if the printer is connected on a Network, to determine the IP Address of the Printer!
Good luck, download the other manuals on the following link in order to change the IP settings on the Printer to what you want
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
What can do to configure my bizhub c300when network setting did not display?
Go to Admin mode, then network, TCP/IP, then enter the IP address, subnet and gateway. SET FOR STATIC IP not DHCP!!!!!!!
Default admin pw 12345678
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 13, 2015 | Konica Minolta Bizhub C300 All-In-One...
Keep getting "limited access" when connecting to netgear wpn824v3
This problem occurs because of ip conflicts in network. For that you need to enable DHCP on router or need to change ip address in computers as your network range. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP enable it then save settings and restart router.. Let me know if you need further assistance. Thanks for using FixYa.
Oct 07, 2010 | Computers & Internet
On my windows vista dell laptop it say limited acess to linksys
"Limited access or no connectivity" message comes when there is issue in ip configuration for that enable DHCP in router then set ip get automatic in your windows network adapter's tcp ip property. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then enable DHCP save settings and restart router then go to your windows network adapter tcp ip property then set ip get automatic.Then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
Aug 06, 2010 | Linksys WCG200 Wireless Cable Modem 54G...
I use the 802.11g enhanced wireless g notebook card and i use the belkin N 150 router but when i try to connect to my network, i will connect to the network but it cant find the network address
For that you need to enable DHCP in router.
http://192.168.15.1
or
http://192.168.2.1
Click on DHCP and enable then save settings and restart router then enable ip address get automatic in network adapter property.
Jul 01, 2010 | Dynex 802.11g Wireless-G Laptop Card
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
My laptop is saying
This error comes when there is same ip address in 2 computers.
So make sure in networks there are not same ip address.
You can also solve this issue with DHCP .
Enable DHCP in router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Enable DHCP if you want to get ip from router.
Then set "ip get automatic " in network adapter property.
Mar 11, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
My computer is telling me "limited or no connectivity." I spoke with my cable company and they said everything was ok on their end and to check with my modem. what should I do?
http://192.168.0.1
or
http://192.168.1.1
Mar 11, 2010 | HotBrick SoHo 401 Firewall
Cant connect to xbox live. ive used my laptop b efore but now it will not let me can u help me? i think the settings are messed up when i test connection from xbox to network it doesnt go any further
First access your router then check its settings of ip address.
It must be in the range of your router settings.
Means if your router ip is 192.168.1.1 and subnet mask is 255.255.255.0
Then your xbox ip is 192.168.1.3
gateway is 192.168.1.1
It is good enable DHCP in your router so your xbox get autoip from router if you set suto ip getting from router.
For that For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then Enable DHCP in router then save settings and restart router.
Jan 31, 2010 | Microsoft Wireless Network Adapter Xbox...
Well my problem is really a network problem, before i was able to surf the net and stay online on my console. But in the past week i am not able to, my console (360) says that my network router is not...
To check your Linksys wireless router settings, open IE browser and type in the Linksys configuration IP address http://192.168.1.1
and login = admin and the PW = admin (if you didn't change the default password) - The default password should be changes to stop unauthorized access into the Linksys router.
If you cannot get into the Linksys router configuration wirelessly, then you need to connect a LAN cable from the computer to the Linksys router.
Check the DHCP and wireless settings. Take a note of the wireless settings (ie SSID, encryption etc.) and check the wireless card setting in the computer, it needs to have these settings for the wireless/LAN to connect to the Linksys router. The TCP/IP settings on the LAN?wireless cards needs to have Obtain IP address automatically and Obtain DNS server address automatically.
Nov 10, 2009 | Linksys Wireless-G WRT54G Router
Connecting new hp deskhjet printer to network
first of all take one computer and unplug the network cable and connect your router with that system through the cross cable and than configure it. To configure that linksys router type the default ip in the browser e.g. http://192.168.1.1 and enter the default userid admin and passwrod admin.
Dec 03, 2008 | Linksys Wireless-G WRT54GS Router...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
602 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
