Question about Kenmore Elite 45986 Front Load Washer
Water not draining.
Ok, I have read what I am supposed to do to clean the drain trap. But where the heck is the drain trap? I see the accordian hose going into the pump in back and I see the drain hose coming out of the pump in front. Do I remove the whole pump? I removed the drain hose clip (after disconnecting power and draining the machine), and can not get the hose to come off the pump. Help and please tell me if I need to disconnect the entire pump or if the "drain trap" is seperate.
Thanks!
  • 447 Answers
You will need to remove the front lower axcess panel. There are 3 torx or 7mm Machine screws securing the bottom of the panel. Once the panel is removed you have axcess to the trap. Its the large plastic screw cap. Be ready to catch some water with a shop vac or other means.
Posted on Nov 24, 2007
Bush manuals
hi there.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
or read up more at this link might help you some more.
washing machine wont spin or drain Google Search
Dec 12, 2017 | Washing Machines
Got a exsm680cl washer and it reads error drain not draining
Check the leveling of the machine, if not use a spirit level and use rubber sheets to keep it firm. If the drain hose is detached the water must freely flow out in this case. If not adjust the slope.
Also check the drain pump to open and work with good action. If not you need to remove and clean the filter and reset the pump
Jan 21, 2013 | Wascomat Parts Wascomat 432 251902 Washer...
MY WASHER WHIRLPOOL LA5430XTW0 AFTER THE WASHING CYCLE IS DONE IT DRAINS OK, BUT DOESNT SPIN, AFTER THAT IT ADVANCES TO THE RINSE CYCLE BUT DOESNT DO ANYTHING AFTERWARDS, IT DOESNT FILL THE TUB, IT DOES...
hi Luis.
Drain Pump
Drive Belt
Lid Switch Assembly
Drain Hose
Coin Trap
What do you do when your washing machine wont drain? Steps
  1. Consult your troubleshooting manual. Most washers come with a troubleshooting manual. ...
  2. Check your drain hose. ...
  3. Run the rinse/spin cycle on your washer. ...
  4. Clean the pump. ...
  5. Turn the handle counter-clockwise to remove the screen. ...
  6. Remove everything from the screen and rinse it off. ...
  7. Run the rinse/spin cycle again
https://www.wikihow.com/Fix-a-Washer-That-Won%27t-Drain
Dec 12, 2017 | Whirlpool Washing Machines
It will not let the water out or spin I think it is the water pomp how do I change the pump I have a frigidaire tumble action washer
First try pressing the start and cancel buttons for about 3 seconds and see if there is an error code, then you can troubleshoot from there....Have you checked the drain lint trap? It is inside the accordian looking drain hose that attaches the drum to the pump. It may be clogged. Use a wet/dry shop vac to remove as much water as possible. Unplug the machine. then remove front panel and remove clamps to check if it is clogged. Hopefully that is the problem!
Mar 25, 2011 | Frigidaire 14 Cycle Tumble Action Washer
I have a candy CMI 146 ACTIVA SYSTEM washing machine it stops half way through a cycle. The water does not drain away and the door security light comes on and the door does not open.
  • You probably have a blockage in the drain outlet. heck the outlet trap and then the hose from the bowl to the pump
  • Often coins get in this hose.
  • Goog luck
  • http://www.appliances.cjb.net
Jan 22, 2011 | Washing Machines
My Whirlpool dishwasher will wash fine, but when it drains, it's a slow trickle. I've snaked the line from the sink to the washer, but I can't find a clog. If I try to blow into the drain pipe all I...
Ok, don't fret too bad, help maybe just reading.
Disconnect the drain hose from the sink/garbage disposal, get a big bucket, stick hose in bucket, making sure that end of drain hose does not get lower then the bottom of dishwasher. Turn dishwasher on (to drain mode if possible or just wait for drain mode) and see if water drains like it is supposed to, if not (and drain hose is not blocked with grease) then either drain solenoid is bad, not opening drain trap all the way or your drain pump is defective.
Did you just replace the garbage disposal, common mistake when replacing disposals is failure to remove dishwasher drain plug knockout.
If further assistance is needed, give us the model number of the dishwasher so I know what model I'm working with.
Oct 01, 2009 | Whirlpool 24 in. DU1055XTPS Stainless...
Kenmore washer water pump
If you wish to check the drain pump for obstructions, the following link will give guidance:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link thoroughly. The use of a wet/dry shop vac will come in very handy for draining water from the wash tub and minimizing the mess that is associated with cleaning out the drain pump and/or drain lines. If you have questions, or require additional assistance, please let me know. I hope this helps you.
PS The clean out reservoir on the drain pump simply unscrews and pulls out.
Jan 14, 2009 | Kenmore HE2 Plus Front Load Washer
W620 Drain Hose Goes Where??
The little black hose in the pin trap compartment gets hooked onto the round pin on the door of the pin trap access, that little hose is a bypass hose from the pump inlet
hope this helped
Apr 18, 2008 | Asko W620
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Kenmore Elite 45986 Front Load Washer Logo
116 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
