Question about The Watches
Changes the week days - The Watches
How can I change the days in casio Ef 331
First of all avoid setting the day and day of the week between 9.00 pm and 6.00 am. The day and day of the week may not change in the following day if you do.
Try this,
1) Pull the crown to the first click.
2) Set the day by rotating the crown counterclockwise.
3) Set the day of the week by rotating the crown clockwise.
4) Push the crown back to its normal position.
Hope this will help.
Cheers
May 16, 2016 | Casio Watches
August steiner watch change day of week
Keep turning time round. Day will change every 24hr
Jan 20, 2014 | Steiner & Co August Steiner Pavarotti...
Change day of the week in casio worldtime watch 3198.
On most digital watches, if you properly set the date and year, the day of the week is preset.
Jan 03, 2013 | Casio G-Shock GW300CA-1V Wrist Watch
I can change the time and the number of the day but not the actual day of week
keep turning the day of the week one untill day changes if not keep turning the time untill the day moved dont think that there is a way you can just change day try first 2 first hope this helps ivan
Oct 23, 2012 | Watches
I have a new chronograph Michele watch. How do I change the day of the week without changing the date?
As per the instruction PDF that I just read, the day of the week only changes with each 24 hour rotation. Therefore to change it, you might pull the crown out all the way and wind it through every hour in each day until it advances to the day you want. Then set the correct time. Push the crown in one notch to the second position and wind the dates forward until it stops on the one you want. It doesn't appear that going backwards for either the time (for day of the week) or date works.
Dec 26, 2010 | Michele MW Square Chrono 71-750-CC-311-180...
I am not able to change the day of week in my esprit watch ?
If you were able to change the day of the week by turning clockwise and now you cannot then it will probably need to be looked at by a repairer. Parts have either broken or become disengaged.
Jul 13, 2009 | Guess Collection Textured Dial Watch
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
Day of the week
Switch the watch into 24 hour mode - should be a simple task - while in normal time mode, press one of the buttons other than light, mode or set button - which I'm guessing leaves only one.
I'm guessing that the watch does not show am / pm?
By putting in 24 hour mode, should be easy to get the right day at midnight changeover.
Hope this helps.
Jun 12, 2009 | Timex 1440 53591 Sports Quotient...
Setting day and date on timex watch
For the analog Timex Indiglo with both day and date (CR 2016 Cell on back) and only the single crown available you must first pull out the stem and turn through the hours 24 at a time to get to the correct day(MON,TUES,etc.). Then you can pull the stem out only half way and set the date (1,2,3,etc.). Be careful to attend to the AM/PM time as you turn the stem for the day. Go too far and the day will change at noon and you have to wind through seven more 24 hours to correct it.
Nov 26, 2008 | Timex 27191 Wristwatch
Watches Logo
18 people viewed this question
Top The Watches Experts
vince
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
