Question about Freezers
Fan blows back thru evaporator - Freezers
  • 73 Answers
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
Cooler don't keep temperatur at 36 to 38 evaporator frozzted
Your model number on the body of the freezer will have that. You can also get size of comp. and fan and rotation located on the pieces itself.
Feb 13, 2013 | Traulsen ARI332LP-FHS 208 - 3-Section...
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Side of freezer seems warm
Hi!!
Don't worry about the line, it is supposed to be the way it is. If you are talking about the condenser coil, located on the back bottom part of the unit, with a small fan in front of it, yes, it is supposed to be hot.
The condenser job is to disipate the heat absorbed by the evaporator (the coil inside the freezer). Make sure the condenser is clean and condenser fan is working, also, make sure there is air circulating thru the back of the unit to help cooling the condenser.
The noises you hear, are probably the defrost coil melting the ice on the evaporator, this function is on a timer and happens 3 or 4 times a day.
Good Luck!!
Aug 03, 2010 | Woods 247 cu. ft. Upright Freezer FU25
Freezer not cold enough and fan doesn't blow.
if door was left open for extended period of time it has probably iced up around the evaporator fan, try to defrost around fan area using a hair dryer
Jul 28, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer was fine. I unplugged it, stood it up in back of truck, got to house plugged it in and now it won't get cold. Compressor is working! Help!
that sounds very frustrating and makes little sense. The compressor works but what about the small fan the blows across the evaporator coil. Also, every refrigeration system has a metering device that is responsible for the pressure drop of the refrigerant just before it enters the evaporator coil. It may look like the orifice on a gas appliance with capilary tubles. it will be between the 2 coils on the line opposite the compressor. Look for kinks in the tubing
Nov 22, 2009 | Freezers
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
