Question about Lanzar MXA282 Car Audio Amplifier
How do I turn my amp up...what nobs do I turn?
  • 73 Answers
The purpose of the gain is to match the signal volts RMS coming from the source (CD player, etc.) to the input of the amp for correct power matching and to prevent clipping (damage by over powering).
Here is a guide that will help you set the gain correctly http://www.box.net/shared/uchv4dbk88
You'll need a multi-meter (AC voltmeter, $15 from Radio$hack), Microsoft Excel and a way to burn an audio CD from an MP3 (test tone included).
If you don't have Excel, You can downlaod OpenOffice by Java (SunMicro Systems) for free to read spweadsheets (and you thought spreadsheets were for business).
Set the LPF to just below the highest range of the frequency response of the subs. Meaning if the frequency response of the sub is 20-200Hz, set the LPF to about 180Hz
OR
set the LPF to where the other speakers start off. example, if the speakers start at 150Hz, set the LPF to about 160Hz. This overlap (or crossover - where the term comes from) is the ideal setting.
Set the subsonic (infrasonic) filter to about the same as the lowest setting in the range of the frequency repsonse of the subs. Meaning about 20Hz if that's the lowest in the range (20 -200Hz as above, if applicable).
Don't set the Bass Boost above +2dB (if applicable).
Set the phase to 0 (if applicable).
See my site for more info http://spkrbox1.spaces.live.com
Posted on Jul 31, 2009
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Hotpoint ew91 halogen hob wont turn off
the control may have shorted. replace control(behind the knob).
Sep 10, 2012 | Hotpoint Ovens
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
Mar 21, 2012 | Water Heaters
I hooked up a system in my truck had it for a year everything working fine.i listen to music really loud anyways i have my wires hiddin under my back seat well when someone layed the seat down it cut my...
Because even though your stereo is turned down the gain for the sub is set all the way up so it will still gain a small amount of signal. it is a flaw with some of the newer aftermarket stereos. try turning the nob until the thump stops then change the bass setting on your deck to compensate for the bass loss.
Jan 28, 2011 | Car Audio & Video
Fan control nob on AC & heater dosn't work
if it does not turn you need a complet unit.
if it turn but the fan does not work it could be a fuse or the circuit of the fan or the fan it self.
Aug 14, 2010 | 2006 Hummer H3
Refrigerator temperature was turned down to lowest number (1) and now the refrigerator will not come back on and chill inside when temp dial is increased to higher #'s. Light is on so it is plugged in.
Repalce the thermostate nob which has teeth to hold the nob in desired level. Due to constant usage of turning the nob it would have broken. Please replace the thermostate nob and do not change the setting on and often to avoid such situation. It wil take care of itself without turning it on our own.
Jul 07, 2009 | Refrigerators
The car is all wired the power is good the ground is good the amp work and i have the sub turned on with the nob but the sub doesn't work it has a 800w rms amp and two 400w rms subs mtx 7500
You could have the subs wired in the wrong ohm. It might be turning off the amp and check to make sure that you rca cables from the head unit to the amp are connected right.
Jun 21, 2009 | Car Audio & Video
2005 malibu no heat
Possibility your nob/resistor in the nob is bad. The resistor changes current in corolation with nob position.
Sep 16, 2008 | 2005 Chevrolet Malibu Maxx
Wiring multipal voice coils
u take the woofer and look for the Red/white dot on the possitive and run one sinle wire to the soild black nob and then on the rest of them hook them to the amp the soild red nob to the possitive to the amp and the black and white dot nob to the negitive on the amp hopes this help if it does rate me
Apr 07, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Nobs and switches
I couldn't find any online information. I checked with pyramid. This was their response:
The owners manual is free of charge please send us a request along with a self addressed stamped envelope to the address below:
Pyramid Service Center
1600 63rd Street
Brooklyn, NY 11204
Nov 04, 2007 | Pyramid PB448 Car Audio Amplifier
Lanzar MXA282 Car Audio Amplifier Logo
89 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
