Printer cartridge refill problem
I have HP printer F4200, i got the black cartridge refilled from a vendor, it worked for few days and after that the HP solution center forces me to replace the cartridge even though it has enpough black ink.
please guide to sort the problem.
Regards.
  • 528 Answers
When a cartridge is filled with non-standard ink, the printer will stop recognizing the cartridge.
Posted on Jul 31, 2009
Can you remove the battery from an hp F4480 printer to make it ignore incompatible cartridge message
Unfortunately, this does not work.
With respect to the HP 60 cartridge error message ("Incompatible Print Cartridges") and inability to print with your HP Deskjet F4480 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (which is typical of the 'incompatible error' alert). These same failures can (and randomly do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to A. and B), this will identify which ink cartridge is causing the issue:
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
            NOTE: To our team's knowledge there is no 'cartridge error bypass' method available for the HP Deskjet printer model. The cartridge will mostly likely need to be replaced with a new one.
            Please note that we provide professional ink cartridge refilling services in multiple countries:
            Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
            Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
            Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
            Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
            Fry's Electronics USA Ink Refill Service (34 stores): http://www.frys.com/ads/page51
            Best Buy Canada (4 stores) Refill Service: Downsview, Sherway, Toronto, & Vancouver (additional Toronto Best Buy stores opening in Fall 2014).
            Micro Center USA Refill Service (8+ stores): http://www.microcenter.com/site/content/refill-service.aspx
            We also have ink refilling centers in many University bookstores across the USA & Canada:
            Brigham Young University, Brigham Young University Bookstore - Idaho (BYU-I),
            Cornell University (CU), Kansas University (KU), New York University (NYU), San Diego State University (SDSU), University of San Diego (USD), University of Wisconsin - Madison,
            University of Virginia (UVA): http://www.cavaliercomputers.com/inkjetrefill.asp?
            Queens University (Kingston, Ontario, Canada) & University of Calgary (Calgary, Alberta, Canada)
            Refill Store Map Locator: http://www.go2ris.com/#findstore
            Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
            -Thank you
Jun 02, 2014 | HP F4480 All-In-One Printer
After refilling my Original HP 818 Cartridge....the printer is not accepting it (considering it as a blank/Incompaible cartridge). How can I use refilled cartridge in my Printer( HP D1668)
hi
try cleaning th contacts of the black cartridge and the contacts of the black cartridge carrier with a wet towel
if that is not working you need to replace black cartridge because the printhead of your cartridge has been overheat due air left in tha cartridge
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
May 03, 2010 | HP DeskJet F380 All-In-One Printer
How to refill the cartridge model is "818" and the printer is hp deskjet F4200
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | HP DeskJet F380 All-In-One Printer
How to refill 818 black cartridge
818 blake cartege Error problam not opret my cartege f4200
Aug 27, 2009 | HP DeskJet F380 All-In-One Printer
How do i refill my HP M1005 MFP Laser Printer toner cartridge?
You should not refill the cartridge...they are a one time use only in any HP laser printer. To use a refilled or refurbished cartridge either voids your warranty, and if you have a printing defect as the result of not using HP-branded toner or an refurbished cartridge HP will not be able to do anything for you...I used to work for one of their call centers doing printer support, and this was a common theme.
There are many places that may advertise that they refill the cartridges with HP-approved toner, but that is far from true. In order to keep your printer functioning properly, even though it may cost more, it is in your best interest to only use new HP cartridges in your unit.
Jul 26, 2009 | HP LaserJet 8500 Color Printer
Hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
Jul 21, 2009 | HP Officejet 6500 Wireless All-in-One...
Refillied black ink cart. causes error.
The ink cartridge is bad get a new one after a few times of refilling the ink cartridge they go bad. Hope this helps ya
Cheers
Johnthetr870
May 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp F4200 deskjet problem
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us and install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
Feb 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
Non-HP ink cartridge
I refilled my new hp 60 cartridge at first it works out but after few print outs hp solution center detects that there is a cartridge problem? what should I do? purchasing a new cartridge is so expensive, thnx in advance......
May 07, 2008 | HP Officejet 6310 All-In-One InkJet...
168 people viewed this question
k24674
jasbo
jasbo
