Question about Cannon Canon i960 Photo Printer
Cannon i960 will not print at all including all the maintenance steps. All new ink cartridges are in
  • 124 Answers
Replaced ink cartridges, printer goes through all the motions, but paper comes out blank. I have done all the maintenance steps. What gives?
Cannon ink cartridges go into a print head. This is normally a removable box the ink cartridge sits in.
First remove the head and the cartridges from it. Now try this to clean the old ink off the print head, rub/soak the print head in alcohol. Make sure the print head is complete dry and place the ink back in it and return to the printer. Try to print a page, if you have the same results you need to replace the print head.
Jul 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
How do I open my canon printer to change the ink cartige?
Step 1
  1. Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  2. Step 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  3. Step 3 Wait a moment. The cartridge carrier will automatically disengage.
  4. Step 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  5. Step 5 Carefully pull the tape off the new cartridge.
  6. Step 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  7. Step 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  8. Step 8 Close the printer's lid. Print a test page to ensure everything is working properly. ....plz give feedback..
Nov 15, 2009 | Cannon Canon i960 Photo Printer
Canon i960 won't print black
You'll need a new printhead, once they plug that bad nothing gets them clean again. Make sure the tape is off the top of the cartridge as well
Aug 07, 2009 | Cannon Canon i960 Photo Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Hi!
I had a similar problem with my black ink not printing well. I removed ALL six of the cartridges and used a Q-Tip, which I had dipped in a bottle of Windex. I put a drop on each of the heads (where the ink goes into the printer), immediately replaced all the cartridges and ran one test. It looked better, so I ran a photo to check. Every color was accurate, so I feel the Windex and Q-Tip solved my problem.
Clarowl
Mar 02, 2008 | Canon I960 InkJet Photo Printer
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
Cannon i860 printer will not print
I don't have specific answers, but here are some steps to check things out. When you say 'just shoots out blank pages', do you mean that the print heads don't pass over the page? If they do, check you ink cartridges to see that they are properly seated. If the printer sends out a series of blank or mostly blank pages, the drivers may have become corrupt. Download the latest drivers, uninstall the printer, and install with the new drivers. If you have the latest driver, uninstall and reinstall the printer. Run the head alignment and color tests. Check your printer cable. If you have a spare, try another cable.
May 23, 2007 | Cannon Canon i960 Photo Printer
Cannon Canon i960 Photo Printer Logo
77 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
