Question about Philips Magnavox TS3260C 32" TV
Philips Magnavox 36" @10yr old has perfect sound and black screen
The sound is perfect and we can change channels and hear the correct channel but yesterday the picture started to fade away and now the screen is black but we can still hear perfectly. Is this worth fixing?
  • 27 Answers
Checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Posted on Jul 31, 2009
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Aug 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a plasma TV MAGNAVOX PHILIPS model-42MF7010/17
video processing is done on small signal board. If there is no on screen display ssb would the board to replace as micro processor generates the menu
Jul 14, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips projection no picture
It sounds like you hit the AV button. Try hitting it again until you see a picture.
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips magnavox model# 9p5040c102
Goto www.TvRepairKits.com and get their shrinking/expanding video repair kit. It works on the Philips sets.
Nov 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Philips Magnavox TS3260C 32" TV Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
