Question about Garden
I have a Reflex GL580 and recently fitted a new spool,however,line keeps feeding out too far.Can you advise the correct procedure for securing line to spool.
    President:
  • 1,486 Answers
There are arrows pointing to the direction witch way the string is to go on.
Posted on Aug 01, 2009
Need to reassemble 2-line trimmer head
Best way is to feed a length that will fit on the spool (for .80 you can probably get at least 10 feet). straighten and place the two ends side-by. Essentially you have two equal lengths). feed each end into the spool holes. Now it is a matter or managing the two lengths so that they do not cross over each other as you wrap the two lengths around the spool. Keep the two lengths parallel to each other as you wrap the lines slowly around the spool. Start from the bottom and work your way to the top. Work slowly. Then, while maintaining a bit of pressure, work tour way back down. Make sure you avoid allowing the lines to cross one another. Use your thumb and index finger to keep the lines parallel to one another. Keep the process going from bottom to top and back to bottom, adding another layer of line each time. When both ends are approximately 8 inches long, maintain pressure on the line wrapped around the spool and feed the ends into the body of the edger. Carefully bring the spool to the center of the body cavity, ensuring the spring is centered over the screw hole. Insert and tighten the crew which is attached to the bonce head. When the unit is in operation, the head is bounced on the ground to release and advance addition line. Hope that helps. Bob.
June 12 2017
Jun 11, 2017 | Garden
I have a trimmer that is 1 year old and the line will not feed.I have followed the instructions to the letter but it will not work.I hope you can help me.Thank you.
In my limited experience all but the very cheapest strimmers have a bump feed line head fitted. These aren't foolproof but I find them less bother and less difficult than the manual feed type.
The main consideration seems to be reassembly after winding the new line onto the spool. Most spools have helpful arrows for the winding direction but sometimes the spool will fit on the spindle either way and the position of the spring isn't always obvious. I have one and the spool is marked this side top. The obvious thing is not the right thing as they assume the machine is upside-down.
Once assembled a bump-feed line head should move against the spring with a firm hand pressure freeing the spool so the direction of travel feeds out more line. The correct line diameter is important. If the head will not move up to free the spool it is assembled wrongly or an accumulation of grass, weeds and nettles has fouled the operation and it should be cleaned and maybe lubricated a little.
Apr 24, 2017 | Garden
Janome serger my lock 204D
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
May 20, 2013 | Janome MyLock 204D Serger NEW MyLock 204D...
The string on my grasshog xp gh1000 4, feeds out within 5 mins. What am I doing wrong when I add new string?
Hello, W/D here.
Read all the way through this, with the spool in your hand, before you re-wind the spools. It will make much more sense!
Pull the spool off of the trimmer.
Look on the bottom of the spool. The decimal numbers next to the notches on the edge is your line size (e g. .080). If there are 4 notches, there will be different decimal numbers, indicating that your trimmer can take different line sizes.
Also on the bottom will be arrows, indicating the direction that you will need to wind the line.
Looking at the spool, you'll notice that it is actually 2 spools, and the divider between them has a slot in it. (This will be important in a minute). The section of the spool closest to the bump head is the outer spool, and the spool closest to the machine, with the flat side, is the inner spool.
Insert the proper sized line into the hole in the inner spool core about 1/8", and wind in the direction indicated by the arrows, until the line is just about even with the divider between the two spools, then place the line in the notch that is 180 degrees (on the other side of the spool) from the slot in the divider. When the line is in the notch securely, leave about a 6" tail beyond that, and snip the line.
Wind the outer spool in the same manner, but this time, the line will go into the slot in the divider, then into the notch, and also get a 6" tail.
Feed the tails into the grommets in the trimmer head, square them up, notches to grommets, and snap the spool in.
Push the spool in like you were bumping it to the ground (this frees up the advance for the spool).
Grab the two tails, and give a tug. The line will pull out of the notches and advance about 1".
It's a good idea to clean out the hole where tha spool fits onto the trimmer from time to time, and also to put some graphite dust in the hole every 8-10 times you re-wind the spools, just to keep the mechanism working freely.
Best regards, --W/D--
Feb 09, 2011 | Black & Decker Garden
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
Oct 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
Ryobi 725R weedeater
First unscrew the bump line leter outer. Then remove the yellow line holder, you will see 2 line grooves for each of 2 lines you will wind into the spool. You will see an inlet area at each of the 2 line holders, you will take about 8-10 feet of line and thread the line into the the groove inlet it will poke out the top of the spool. You will see 2 small holes on the top of the spool, feed just the tip of the line into the hole and pull the line tight on the groove side. Do this on both grooves on the spool, once the line is secure, fish each line into the holes on the spool head and secure with the bump spool leter outer. After spool is secure take the entire spool and wind back into the spool head. you will see the line wind into the spool. make sure you wind the right direction. Once you have seen how this is done, look at the bottom of your assembled spool and you will see 2 arrows. If you have no line in the spool, line up the arrows and take 8-10 feet of line and feed as you did when you have the spool removed. The line should feed through the spool and the line will stick up from the bottom, turn the line and feed just the tip of the line into the retainer hole and pull tight from the spool let-out, once secure wind line back into the spool. Once you have done this once its very easy to do over and over!!!
Jul 21, 2008 | Electrical Supplies
Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
May 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
