Question about Microsoft Xbox 360 Console
The disc I purchased doesn't work,
The disc I purchased in doesn't work, message saying insert this disc into xbox360 console but it already is and doesn't load the game.
    Problem Solver:
  • 10 Answers
DO OTHER GAMES WORK? IF NOT THEN ITS YOUR LASER.
Posted on Aug 04, 2009
When I put any disc(game or cd) in my xbox360, it
When last did you clean the pick up lens on the console?
Sounds like the pick up lens is not reading the disc, any hard collisions on the console recently? If you have the correct lens cleaner at hand I would advise a cleaning asap, see if this solves the issue.
Oct 24, 2013 | Microsoft Xbox 360 Console
Xbox360 disks wont reed
I'll need some more information to truly help you,
Is the disc spinning when you put it in (can you hear it trying to read)
What does the xbox dashboard say when a disc is inserted? Are there any error codes or "no disc inserted" message?
Try another game disc if you can. Sometimes discs get scratched or dirty, in which case you can clean it or have it professionally cleaned.
If that doesn't work, Try cleaning your laser lens
There are several places that will clean your laser lens, or if you're a little more technologically inclined, You can open your system yourself and clean the lens with some alcohol and a q-tip.
If none of the above works, you may need to have your xbox professionally repaired.
May 08, 2012 | Microsoft Xbox Xbox 360 Arcade System...
I put in a disc. it says reading then goes back to open tray. Help me.
The most common reason for the Console saying reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Console including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Console going again!
Hope it works...
May 31, 2010 | Microsoft Xbox 360 Console
My xbox360 game mercenaries2 does not work it allways turns of.
IS it giving you an error message?
If the 360 is shutting itself off, then this has nothing to do with the game, and you have some form of power supply problem. Try a different game. If it still does it, you most likely need a new power adapter. If you are getting an error message (unplayable disc/dirty or damaged disc) Then the most likely cause is your optical lens in the DVD drive is dying.
Jan 07, 2010 | Microsoft Xbox Console
Player faild to load content
Its possible that your Xbox360 is having a hard time reading your game disc. Try to clean your Xbox360's lens by using a CD lens cleaner. If you are still having problems after doing that, its possible that your game disc is already bad.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Microsoft Xbox 360 Console
Why do my xbox360 says play dvd when i inserted my 360 game disc
not much u can do send it in no warrenty, no problem over heat the thing intill u get three red lights and make sure it has red lights and microsoft will fix it for free
Aug 16, 2009 | Microsoft Xbox 360 Console
Xbox360 wont play games when inserted in console.
im no expert but i think that it could be ur lazer bein dusty i suggest that you get a dvd lens clener with bristles on the part of the disc that the lazer reads and try that ok
Jan 11, 2009 | Microsoft Xbox 360 Console
When I put any game disc of my xbox360 into the console, it says 'this disc must be inserted into an xbox 360 console' What do it do
An OS File Has Been Overwritten. Call Microsoft And Tell Them What Your X-BOX 360 Says. They Should Replace The OS
Jul 02, 2008 | Video Game Consoles & Games
No games will play
You xbox 360's dvd drive is damaged. If you just purchased it return it. If you are out of the return window you'll need to contact microsoft and see if it's still under warranty.
There's really no other way around this problem, you must get the drive replaced.
Jan 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
