Question about Sony Televison & Video
Kdl-40v2500 standby lamp blinks 4 times - Sony Televison & Video
mistersony
  • 320 Answers
SOURCE: I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
Posted on Nov 26, 2008
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
welcomejee
  • 10594 Answers
SOURCE: standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Posted on Jul 30, 2009
dsacco86
  • 1077 Answers
SOURCE: 13 standby blinks. Sony KDL-52W3000
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
Posted on Sep 03, 2009
welcomejee
  • 10594 Answers
SOURCE: Have the same problem--my KDL-40S2000
4 times red standby light blinking shows problem of back light failure for some reason.
Possible cause could be either back light inverter boards are defective or power supply board is not providing proper voltages to that inverter boards to function properly.
Power supply board is available separately but back light inverter boards come along with new lcd panel (screen) and it would be costly fix as lcd panel cost would be more than tv worth.
Let me know your expertise level to provide you further info.
Thanks.
Posted on Oct 05, 2010
Blank screen flashing red light 8x
Eight time blinks to sony TVs indicates Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
May 12, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Standby flashes 3 times pauses and flashes again. can't get tv to turn on
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 12, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Black screen , red standby light flashing 4x repeatedly, unplug it and the green light comes on momentarily then resorts to 4 red flashing lighrts again. Sony KDL-40V2500 approx. 4yrs old. HDMI cables are...
4 blinks indicated of backlight malfunction. The unit shutsdown to avoid overload to the inverter board.
Check the backlights, busted backlight has a physical indication of fault like blackened end, crack end. You must replaced the busted one and your unit will back to normal operation again.
Hope I helped you.
Have a nice day!
May 16, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Standby lamp keeps on flashing.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Jan 05, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
252 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
