Question about Sony VAIO VGN-T1XP/L Notebook
How to remove the screen bezel - Sony VAIO VGN-T1XP/L Notebook
  • Sony Master
  • 32,281 Answers
There are screws hidden behind round plactic covers on the bottom and sides of the bezel. Also they may have plastic clips and or double sided tape holding the bezel in place. Slip a thin blade between the screen and bezel and gently lift the bezel off, take care not to scratch the LCD screen.
Posted on Jul 31, 2009
HOW TO REPLACE e5420 INVERTER
The inverter is located on the bottom of the LCD screen between the hinges. Remove the screws that secure the bezel, the bezel may also be stuck to the screen with double sided tape. Be CAREFUL you do not damage the LCD screen when you remove the bezel.
Apr 05, 2012 | Dell Computers & Internet
Inverter
The inverter is located on the bottom of the LCD screen behing the LCD screen bezel.
There are screws fixing the bezel in place and the bezel may also be secured with double sided tape.
Care must be taken to avoid damage to the bezel and LCD screen when you remove the bezel.
Mar 25, 2012 | Sony VAIO VGN-AR605E 17" Laptop
How do you remove the screen
Televisions covered: typical Projection Televisions.
Projection TV's usually have a bezel surrounding the screen that is held on by a (firm) friction-fit to a rubber gasket.
Once the bezel is (carefully) removed, the screen itself is released.
How to remove the bezel: carefully pull it away from the cabinet of the TV (toward the front), by hand - its somewhat/slightly flexible. If a tool is used, one risks damaging the cabinet finish, or the bezel itself.
If I need to extract a screen, I'll usually release the upper 1/2 of the bezel from around the screen (removing the top and half of each side), then lift the screen panel itself up and out of the TV without removing the entire bezel - this way, I save the (unnecessary) work of removing the entire bezel, and also avoid the possibility of the screen panel falling out of the cabinet onto the floor in front of the set (as the last part of the bezel comes off the cabinet).
Its often tough to get this bezel off the first time, so when I take one off, I'll install a light coating of grease on the rubber gasket, since once it comes off the first time, it will inevitably need to come off again a few more times before the TV is fixed. And if the bezel is flexed too violently, it will break.
Cheap automotive bearing grease works fine.
Dec 23, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Need to know how to replace a cracked screen on dell adamo 13
Hi
Click here to know how to replace and also to know more about the replacement instructions.
Regards,
Saleem
Jul 14, 2011 | Dell Adamo 13
I want to replace the LCD screen myself but I can't find any video that shows me how. All of them show laptops that screws on the front of the bezzle and mine doesn't. How do I get the bezzle off?
Here's how to remove a screen for a laptop with a front bezzle instead of just front screws:
1. Power down your laptop. Disconnect the power cable and any peripheral devices from the laptop. Close the LCD screen, flip the laptop over and remove the battery from the bottom casing of the laptop.
  • 2.Flip the laptop over, and then open the LCD screen all the way. Remove the rubber screw covers from the front LCD bezel. The screw covers will be located on the front of the panel, or along the side edges, depending on your laptop's make and model.
  • 3.Remove the retaining Phillips-head screws from the front LCD bezel. Insert a flat-head screwdriver into the gap along the outside edge of the LCD panel. Start to pry off the front bezel. Work your way around the entire LCD panel until the front bezel is separated from the panel.
  • 4. Remove the the bezel from the LCD panel and set it aside.
    Source: http://www.ehow.com/how_6759851_remove-bezel-laptop-screen.html
  • Mar 19, 2011 | HEWLETT-PACKARD G72260US Notebook
    Rca tv is blurry
    2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
    May 06, 2010 | RCA P52926 52" Rear Projection Television
    How to change out a broken lcd screen on an aspire
    http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
    This is its contents without the pictures:
    OK, let’s get inside the display assembly.
    First of all, turn off the laptop, unplug AC adapter and remove the battery.
    The screen bezel* has four screws hidden under for seals. Two rubber seals on the top of the bezel and two plastic seals on the bottom.
    You can remove all four screw seals with a sharp object as it shown on the picture below. Glue removed seals somewhere on the bezel so they don’t get lost.
    Remove four screws found under seals.
    Start remove the screen bezel with your fingers. Proceed slowly while removing the bezel.
    Carefully separate the display cover from the screen and access the LCD cable connector
    You’ll have to unplug the LCD cable from the screen.
    First, unglue the clear sticky tape securing the connection.
    Second, unplug the LCD cable from the connector on the screen.
    Here’s how you can remove the LCD screen.
    Simply remove four screws securing the LCD screen to the display hinge. Remove four more screws from the other side of the screen.
    Now you can remove and replace the LCD screen with a new LCD screen.
    Put all the screws back in there places
    Dec 31, 2009 | Acer Aspire One PC Notebook
    How to removing toshiba satellite a305-s6872 screen
    to remove the screen.... the front plastic bezel needs to be removed first.... Remove the rubber screw covers on the front of screen frame... then remove the screws.
    then use a plastic tool...like a credit card, start at a corner and pull the front bezel towards you .. you need to unsnap the plastic bezel... it is held on by snap locks all the way around it... Pull the front bezel frame off...
    then there are screws on each side of the screen holding it to the hinge post rails.... Unscrew them.... Tilt the screen forward from the top...
    Unplug the Display cable (it is taped on at the plug port..... pull tape downward)
    then unplug the LCD bulb Cable from the inverter...
    Dec 26, 2009 | Toshiba Satellite Laptop
    Replace laptop screen
    STEP 1.:-Turn off the laptop and remove the battery.There are no screws securing the screen bezel. Start separating the screen bezel from the display cover with your fingers.
    STEP 2.:-Continue removing the screen bezel on the top.
    STEP 3.:Remove bezel from the hinges.
    STEP 4.The screen bezel has been removed.
    STEP 5.:Remove six screws securing the LCD screen assembly.
    STEP 6.:-Separate LCD screen assembly from the display cover.
    STEP 7.:-Place the LCD screen assembly face down on the keyboard. Now you can access the back side of the screen and disconnect cables.
    STEP 8.:-Disconnect the video cable connector from the LCD screen controller board.
    STEP 9.:-Parts of the video cable could be glued to the screen. Unglue the cable.
    STEP 10.:-Disconnect cable from the inverter board.
    STEP 11.Remove the LCD screen assembly.If you are replacing the LCD screen you’ll have to transfer mounting brackets from the old screen to a new one.
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Dec 23, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
    How do I remove the invertor from a Qosmio F20?
    The inverter is located behind the bezel at the bottom of the screen/lid and in between the hinges.
    The bezel has screws that fixes it to the lid and these can be hidden by stick-on plastic covers. Use a thin sharp point to lift these plastic covers off to reveal the screws. Remove these screws.
    The bezel has small plastic catches that clips it to the lid and may also be fixed to the LCD screen with double sided tape. Use a thin blade and insert it between the LCD screen and the bezel and gently ease the bezel off. Start at the bottom of the screen and gradually work along the edge and continue around each side to free the bezel.
    Be CAREFUL not to scratch the LCD screen and DO NOT apply too much pressure to the face of the LCD screen because you can crack the glass surface and ruin the LCD screen.
    Once the bezel is removed then you can get access to the inverter to remove it.
    Nov 16, 2009 | Toshiba Qosmio G15 Notebook
    Sony VAIO VGN-T1XP/L Notebook Logo
    289 people viewed this question
    Top Sony Computers & Internet Experts
    Martin Murray
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
