Question about ASUS A7V8X Motherboard
Beeps after changing ram have removed new ram still just beeps
Beeps after changing ram have removed new ram wont load to cmos or initialise video card.
  • wayne351 Jul 31, 2009
    long beeps with + - second pause in between
  • ultimitloozr May 11, 2010
    What is the pattern of beeps?
    President:
  • 1,185 Answers
While not wanting to be a prophet of doom I do believe that you have killed your Motherboard.
Unless you get Ram which is a spot on match for the board one of the side effects can be a wipe out or corruption of the Bios.
You may be able to get support from Asus direct by clicking on the link below
http://support.asus.com/default.aspx?SLanguage=en-us
Posted on Jul 31, 2009
  • ASUS Master
  • 32,281 Answers
The beeps error means the RAM is either incompatible or faulty.
If you use the same make but larger size memory module as the original RAM this should fix your problem.
Hi mine wont show screen at all! i reset ram no help. i turn it on no screen n after about 20 secs it has one long beep?? i cant tell if its loading or not!
the long beep indicates faulty ram oir graphics card, i would say ram, you also need to reset the bios, via the cmos jumper or battery, continuous long beep is a dram error, so the ram is faulty, get some new ram and make sure its specs match the computer
Feb 14, 2011 | Gigabyte GA-945P-S3 Motherboard
Tip
Beep Codes (Different BIOS) " What they mean "
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
on Dec 30, 2009 | Computers & Internet
Beeps on my computer
If its a Repeating short beeps, this tyically implies power supply or mainboard issues. However here is list of Pachard Bell Beeps codes for the main boards.
Beep Code Description
1 1 3 CMOS read/write failure
1 1 4 ROM BIOS checksum error
1 2 1 Programmable interval timer failure
1 2 2 DMA initialisation failure
1 2 3 DMA page register read/write failure
1 3 1 RAM refresh verification failure
1 3 3 First 64k RAM chip or data line failure
1 3 4 First 64k RAM odd/even logic failure
1 4 1 Address line failure first 64k RAM
1 4 2 Parity failure first 64k RAM
2 1 1 Bit 0 first 64k RAM failure
2 1 2 Bit 1 first 64k RAM failure
2 1 3 Bit 2 first 64k RAM failure
2 1 4 Bit 3 first 64k RAM failure
2 2 1 Bit 4 first 64k RAM failure
2 2 2 Bit 5 first 64k RAM failure
2 2 3 Bit 6 first 64k RAM failure
2 2 4 Bit 7 first 64k RAM failure
2 3 1 Bit 8 first 64k RAM failure
2 3 2 Bit 9 first 64k RAM failure
2 3 3 Bit 10 first 64k RAM failure
2 3 4 Bit 11 first 64k RAM failure
2 4 1 Bit 12 first 64k RAM failure
2 4 2 Bit 13 first 64k RAM failure
2 4 3 Bit 14 first 64k RAM failure
2 4 4 Bit 15 first 64k RAM failure
3 1 1 Slave DMA register failure
3 1 2 Master DMA register failure
3 1 3 Master interrupt mask register failure
3 1 4 Slave interrupt mask register failure
3 2 4 Keyboard controller Test failure
3 3 4 Screen initialisation failure
3 4 1 Screen retrace test failure
3 4 2 Search for video ROM in progress
4 2 1 Timer tick interrupt in progress or failure
4 2 2 Shutdown test in progress or failure
4 2 3 Gate A20 failure
4 2 4 Unexpected interrupt in protected mode
4 3 1 RAM test in progress or failure>ffffh
4 3 3 Interval timer channel 2 test or failure
4 3 4 Time of Day clock test failure
4 4 1 Serial port test or failure
4 4 2 Parallel port test or failure
4 4 3 Math coprocessor test or failure
low 1 1 2 System Board select failure
low 1 1 2 Extended CMOS RAM failure
hope this helped
-Keiffertech
Jun 18, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Pc boots but no display. tried a new video card, still wont work. ram or motherboard?
Hi.
To start the troubleshooting,
Do one thing.
Clear the cmos.
To clear the cmos, remove the battery and the cmos jumper. You will see JCC on the mb and it is attached to pin 1&2
You can Short it to pin 2&3 or remove it completely.
Don't forget to remove the power-cord from the power supply while clearing the cmos. together with the cmos bat & jumper.
After that try a different ram and a different vga card.
At times dust get accumulated in the slot that prevent firm contact with the vga slot or the memory bank.
Use a clean paint-brush and blow away the dust on the card, the mem and also the slot in the mb.
Fix it firmly.
try this
If you need further assitance revert back
Good luck
Uttam
Feb 18, 2010 | Computers & Internet
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
Video quit...then everything
You computer did not pass the game requirements.
Mar 12, 2009 | EPoX EP-8VTAI Motherboard
4 beeps 2373 laptop
Code Description
Code Description
200 - 299 Memory
300 - 399 Keyboard
AMI BIOS Beep Codes
Code Description
Code Description
2-_-_ Faulty Memory
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
ASUS A7V8X Motherboard Logo
173 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
