Question about Pentair 2" Pvc, 3 Way Lube Free Diverter Valve, with 2.5" Slip Outside
Which positions of the handle divert waater
What positions of the handle correlate with the diversion of water?
My problem is keeping the water level in the spa to stay. It drops about a foot when I turn off the pumpms. There is also a water feature in the mix adjacent to the jacuzzi.
    President:
  • Pentair Master
  • 1,378 Answers
The 'stop' is opposite the direction the handle extension points, so in the picture shown with this post the port pointing left is closed and the ports facing down and right are open.
Posted on Jul 31, 2009
How do I set up a call divert
If this is an exchange line, and the facility is enabled, in Europe and the UK, you would key *21*01234567891# where 01234567891 is the number to which you want to divert the call.
Wait for a voice announcement, and the exchange will tell you that you have turned diversion on. You will frequently hear a different dial tone as a result.
To remove diversion, key in #21# and the dial tone will revert to normal. The exchange will also advise you of the diversion's cancellation.
Feb 11, 2015 | Lands Phones
Need to get handle off of pantera sand filter
You need to remove the "key assembly" before removing the handle. The key assembly is the lid, handle and diverter which all come out in one piece after taking the bolts out around the lid.
Once the assembly has been removed, you need to compress the lid down toward the diverter to allow the handle to move freely. At that point the handle pin, which connects the handle to the diverter may be removed. Note the position of the handle's pointer and the open slot on the diverter. When reassembling it is important that they are in the same position. If not careful the handle will be 180 degrees off.
Its a good idea to go ahead and change out the diverter o-rings and bearing on top of the lid (that the handle slides upon while turning) while you have it open.
Mar 13, 2013 | Pool & Spa
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
What is the barring code for Nokia n70?
The @ represents pressing the "Send" key on your mobile
##002#@ all call diverts off
*#06# IMEI Number showing
**004*DestNo#@ set all conditioned call diverts to DestNo on and active
##004#@ all conditioned call diverts (busy, not reachable, no answer) off
**21*DestNo#@ Automatic divert all calls to DestNo on and active
*21#@ Automatic divert all call DestNo activate
##21#@ Automatic divert all calls to DestNo off and inactive
#21#@ Automatic divert all calls to DestNo deactivate
*#21#@ Automatic divert all calls to DestNo status
**61*DestNo#@ Call divert when not answered on and active
*61#@ Call divert activate
##61#@ Call divert when not answered off and inactive
#61#@ Call divert deactivate
*#61#@ Call divert when not answered status
**62*DestNo#@ Call divert if not reachable on and active
*62#@ Call divert activate
##62#@ Call divert if not reachable off and inactive
#62#@ Call divert deactivate
*#62#@ Call divert if not reachable status
**67*DestNo#@ Call divert when busy on and activate
*67#@ Call divert activate
##67#@ Call divert when busy off and inactive
#67# Call divert deactivate
*#67#@ Call divert when busy status
**03*330*oldPW*newPW*newPW#@ Changing the password for call barring
**33*PW#@ Barring all outgoing calls on (PW one row before)
#33*PW#@ Barring all outgoing calls off
*#33#@ Barring all outgoing calls status
**330*PW#@ Barring all calls on
#330*PW#@ Barring all calls off
*#330*PW#@ Barring all calls status
**331*PW#@ Barring all outgoing international calls on
#331*PW#@ Barring all outgoing international calls off
*#331#@ Barring all outgoing international calls status
**332*PW#@ Barring all outgoing international calls except homecountry on
#332*PW#@ Barring all outgoing international calls except homecountry off
*#332#@ Barring all outgoing international calls except homecountry status
**333*PW#@ Barring all outgoing calls on (PW one row before)
#333*PW#@ Barring all outgoing calls off
*#333#@ Barring all outgoing calls status
**35*PW#@ Barring all incoming calls on
#35*PW#@ Barring all incoming calls off
*#35#@ Barring all incoming calls status
**351*PW#@ Barring all incoming calls if abroad on
#351*PW#@ Barring all incoming calls if abroad off
*#351#@ Barring all incoming calls if abroad status
**353*PW#@ Barring all incoming calls on
#353*PW#@ Barring all incoming calls off
*#353#@ Barring all incoming calls status
*43*#@ Call waiting on
#43##@ Call waiting off
*#43#@ Call waiting status
**61*DestNo**Seconds before divert#@ Divert call if not answered for 'seconds' (Note: Seconds must be 5, 10, 15, 20, 25, 30)
#30#DestNo@ No presentation of the number of the incoming call (CLIP)
*30#DestNo@ Presentation of the number of the incoming call (CLIP)
*#30#@ CLIP status
#31#DestNo@ Your number will not be send for the actual call (CLIR)
*31#DestNo@ Your number will be send for the actual call (CLIR)
*#31#@ CLIR status
*76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) on
#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) off
*#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) status
*77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) on
#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) off
*#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) status
Jun 10, 2011 | Nokia N70 Cellular Phone
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
One Handle Tap has gone random and hot/cold keep moving position.
look under the cap for a screw,see if you can tighten,if no screw under the handle is a plastic piece that is attached to the faucet diverter,this may have broken or the screw has come loose.you may have to replace the handle
Jul 30, 2009 | Plumbing
Pentair 2" Pvc, 3 Way Lube Free Diverter Valve, with 2.5" Slip Outside Logo
225 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
