Question about Sewing Machines
3116: stops stiching immediately, bobbin thread in ball..sos
Begin to sew, stiches a few throws then machine stops, gets stuck and i have to rip (ouch!) my fabric out and the bobbin thread is all knotted!
tension?
thanks alot
ak
  • Sewing Machines Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
3116: stops stiching immediately, bobbin thread in - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
bargainbox.com.au
Posted on Aug 02, 2009
Why is the bobbin thread being cut on bobbin after a few stiches? machine will sew a few stiches and this happens.
your bobbin is place in the wrong position and you need to tighten the stitch....adjust it a bit.....play with it till you get the desire result
Sep 11, 2014 | Singer Sewing Machines
When iam stiching the bobbin thread is not interlocking with the pool thread ,the straight stich is not stiching properly
Do you have thread in your bobbin?
Is your needle fully inserted in the needle bar?
Is it the right needle for the machine?
Is your needle damaged, bent or dull?
Jul 26, 2012 | Singer 7470 Computerized Sewing Machine
I have 3116 singer machine, the stich is not grabing the bobbin thred and it is making a knots in the back of the fabric what should i do?
Bobbin thread is backwards.Turn the thread around before inserting it into bobbin locaction.It MUST be put in correctley or this problem will never stop.Check your threading Bobbin Instruction CLOSLEY,I found this out the hard way too.Good Luck.
Dec 05, 2011 | Singer 3116 Simple
I have a singer 3116 sewing machine. It works fine for the first couple stiches and then its starts making this weird noise and the thread gets cought around the bobbin case under the machine. I tried to...
Call Singer if this persists, without hearing the sound I would only be guessing what the problem is. The phone number is 1-800-4singer for customer service.
Nov 21, 2010 | Singer 3116 Simple
Tread breakage snd stich skipping
(A)Put in a new needle and rethread from the beginning. Make sure the take-up hook is threaded. Also, (B) clean lint out - sewing machines have very small margin for error when lint pushes everything out of alignment. Mostly, it sounds like your thread is stuck somewhere, which can even be at the spool, so (A).
Apr 06, 2010 | Juki DDL-8700
Jaming thread in the botton acts like it is droping stiches
Check the tension on your bobbin/ underspool.
Sometimes thread dust can jam the thread brake in that area and **** the locking stitch back out.
Mar 09, 2010 | Singer 3116 Simple
Upper thread breaking on singer machine
Check that your bobbin thread is not wound too tightly or too loose. Also adjust your tension down a click at a time until it stops breaking, testing on scrap fabric. Singer provided manuals online. Look it up here: http://www.singerco.com/accessories/manuals.html
Sep 10, 2009 | Singer 3116 Simple
I HAVE Kenmore 385 165 24 bobbin case is loose and I can not get even one stich. Do I miss a srew to hold it in a place? Thanks for help.
if the bobbin case is loose and pops out when started. it is not inserted correctly
make sure you hold the clasp when inserting case and hear the slick into place
make sure upper thread is threaded right and the bobbin thread is even
bring bobbin thread up and pull both threads to the back about fou inches
hold threads and stich a few stiches by hand or foot pedal befor letting fo of the thread.
Aug 26, 2009 | Kenmore Sewing Machines
Does not make a stich
you may find that the needle is bent. or maybe the machine needs a cleaning I use canned air for this it blows the lint out so nicely . if this is a new machine then take it back to where you bought it and see what they can do.
Feb 26, 2009 | Singer 3116 Simple
I can't seem to ever get the tension right on my "singer simple". no matter what i do, the stiching is a problem. this is my second machine with the same problem, is this a mfr defect or...
Probably operator error. Make sure the machine is threaded right, make sure the bobbin is threaded properly, change the needle.... even though you think the needle is sharp. Make sure you are using the right thread. If you have bargain thread, throw it out. Use Coats & Clark, which is still reasonably priced. My friend has a lower end Singer that was acting up ... loose threads on the bottom of the fabric, which means upper tension .... we did the simple thing of changing the thread. It worked, and the machine is sewing beautifully.
Apr 14, 2008 | Singer 3116 Simple
Sewing Machines Logo
76 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
