Question about Acer Aspire One Netbook 8.9" Notebook
Netbook acer one not recharging the battery
Even when the netbook is plugged in, the battery will not show it is charging or perform when later unplugged.
This seems to be a common problem, appearing often in searches I have made. What shuld I do?
I have the same problem as above.
Battery seems to be dead all the time.
Does not charge at all.
    Scholar:
  • 141 Answers
Your charger might be dead, check his output with a voltmeter if you get some juice. It should be around 19 Volts. Then it might loose his power with a charge (when you plug it onto your laptop) so you can try to connect a car light bulb to it . If get light then probably the motherboard of your laptop has issues, if no lights then you can replace your charger.
Cost in average 45 USD.
good luck
Posted on Jul 31, 2009
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
My acer netbook batteries will not charge. Any suggestions?
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Nov 08, 2011 | Acer Aspire One D255-2670
My Acer aspire one just stopped working for no reason. I plugged it in to charge it but none of the lights come on, and nothing happens when I hit the power button...
Assuming that the AC/DC Power Adapter is not faulty no LED lighting up at all and no image at all on the screen might mean a power management fault on the motherboard.
First try removing the battery underneath the netbook. Then connect the netbook to the power cable without the battery installed. If the netbook powers up without a battery installed then the battery is probably faulty most likely with completely depleted and unchargeable power cells. if so you will almost certainly need a new battery and some little known guidance on the correct management of a netbook or notebook battery (see below). Dead batteries tend to generate a more than normal amount of heat.
If the AC/DC adapter is not faulty and using the netbook without a battery does not help then check the DC power jack where the power cable connects to the netbook to see if the jack is loose or detached from its original solder point on the motherboard.
If the none of the above are the cause of the problem then the motherboard probably has a power track or capacitor fault which might be repairable (as would a loose DC jack) but these types of fault even if successfully repaired can easily come back and the cost of repair might be high compared to the value of the netbook and not worth it since a brand new state of the art netbook with a full warranty would not be very expensive.
Many users take an incorrect approach to netbook/notebook/laptop battery management. These batteries are rechargeable and are only supposed to be connected to the power cable when their cells are low or depleted. Once the cells are fully charged the power cable should either be disconnected and the computer used on battery power alone or the battery should be removed and kept for when battery powered use of the computer is next needed.
Once a fully charged battery is removed the computer can be used directly connected to the electricity without the battery installed.
A disconnected battery needs to be reinstalled and recharged from time to time if it is stored for long periods of time, because the charge in its power cells very slowly dissipates even if is disconnected from the computer.
Nov 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
My em350 version NAV51 charging but its battery level does not exceed 25% even if it is left to charge with the laptop switched off
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 22, 2011 | Acer eMachines 350-2074 Netbook
I had my plugged in my laptop in overnight and took it off charge to use it today within 20mins after i turn it on, it was down to 59%. What solutions are there to fix the broken?
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
NETBOOK WONT TURN ON WITH OR WITHOUT BEING PLUGGED IJ WHEN THE NETBOOK WAS PLUGGED IN AND CHARGING, THE BATTERY HAD 100%. STARTED TO USE THE NETBOOK AND THE BATTERY LEVEL WENT TO ZERO %. NOW EVEN WHEN...
  1. Remove the battery for 15 seconds, and make sure the contacts are clean and free from dirt, dust, etc.
  2. Reinstall the battery and try to turn the netbook on.
  3. If it still doesn't work, replace the defective battery.
Jan 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One battery not charging
your probably going to need a new battery
Mar 25, 2010 | Acer Aspire One AOA150-1784 Netbook
Acer netbook battery sits at 0% charge
contact to autorised service in your country. take your adapter too :).
May 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
828 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
