How old is my hotpoint first edition wma11 - Washing Machines
  • 82 Answers
There should be a date code on the inside of the door
Posted on Jul 31, 2009
4 Suggested Answers
  • 662 Answers
SOURCE: hotpoint wma11 where is the filter?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
  • 40 Answers
SOURCE: My Hotpoint first edition WMA11
check to see if you can use a small object to simulate close door if works switch needs to be adjusted
or replaced
Posted on Jun 10, 2011
  • 5 Answers
SOURCE: I have a hotpoint first
first check outlet hose at sink end grease can build up on connection at trap under sink,if this is clear first dcoop out as much water from drum and lay outlet pipe flat into low basin to syphon water out ,when drained make sure the machine is isolated,take off lower back panel if you look in you will see black sump hose attached from bottom off drum to pump remove sump hose from drum by undoing clamp and insde is plastic float ball check to see if anything is blocked if clear re attach and remove pump take off pump housing (three screws) check if anything is in pump if clear change pump
Posted on Sep 08, 2011
How to take out a coin from inside of hotpoint wma 11
front cover should pull off on washer to let u at filter
Mar 14, 2015 | Hotpoint WMA11 Front Load Washer
Machine starts then program end light flashes constantly and has done nothing?
I had similar problem and Eventually replaced motor brushes which solved the problem
Feb 26, 2012 | Hotpoint WMA11 Front Load Washer
Wma11 starts to load water then goes to end program within seconds
hi try another program like spin cycle if is still the same the programmer timer control could be the fault
regards
shaun
Dec 05, 2011 | Hotpoint WMA11 Front Load Washer
Machine will not do fast spin
brian in the past i have had insurficient items in the machine causing this problem try adding extra items.Some machines are sensitive to balance
Oct 19, 2011 | Hotpoint WMA11 Front Load Washer
My Hotpoint first edition WMA11 will not start as it does not recognise that the door is closed.
or replaced
Jun 09, 2011 | Hotpoint WMA11 Front Load Washer
Hotpoint wma11 where is the filter?
May 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Water continues to flow into the detergent box,albeit slowly,until the drum is full to overflowing Model no, WMA10
in the sump hose there is a plastic tube about 6 inches long and it gets blocked.make sure the hose on top of this tube is connected to pswitch in the top.
Sep 14, 2009 | Hotpoint WMA11 Front Load Washer
How to change brushes on wma11, mainly how to i get the top off?
There are two screws on the rear of the lid, one near each corner, undo these and lift the rear of the lid a little and pull back to release the front from its clips. ( but first, if I am correct in thinking the motor is underneath on these, tilt back the machine and lean it against a wall or cabinet, and look to see if it's underneath.
Jun 15, 2009 | Hotpoint WMA11 Front Load Washer
My hotpoint wma11 sounds like its washing rocks,bearings gone?
Unfortunately yes if this sound appears when the drum is spining, if when drum is still, than the pump wearing out
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint WMA11
If the motor is not getting power when it is called for spin. Then check the computer and the timer. Also check the balance sensor
Feb 14, 2009 | Hotpoint WMA11 Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
