I bought a new samsung Metro 3310. It has 1GB MEMORY CARD.But the phone memory is less. The datas downloaded to the mobile using bluetooth is straightly saved into the phone memory first. So the data or songs with big size than the phones memory can not be downloaded to the phone. If I try to download such songs, the phone will show that the phone memory is full. I want to songs to be downloaded to the memory card instead of phone memory. What should i do?
Go to settings in your phone and select the option to store ,in external memory card and down load.Now the downloaded items will be stored in the memory card.Also change the external memory card to higher capacity, that is to 4GB/ or 8GB.
Solution 1: Set to save the files into SD card rather than into Phone memory. For example, set song folder and picture folder to a location on memory card. Refer to the phone manual for detailed steps.
Solution 2: use a computer and card reader to manually store songs into SD card. Then set the phone to folder into sd card to get the songs. Clear phone memory afterward.
Your phone can't use the mini SD card as internal memory. Your internal memory has to many apps, and to much data. (pictures, notes and messages) You should clear up the internal memory, by deleting apps and data. Most Samsung apps you can't delete. The modern phones already have apps, exceeding 10 Gb. So if you bought a 16 Gb phone only 5 Gb is left for you to use for apps. I'm sorry, but the SD cards should be seen as an external hard disk, not as internal memory.
If you thought I can buy a phone with less memory, because the SD cards are very cheap and will extend the internal memory, you made an error. New phones from Samsung now get more than 10 Gbyte of apps, you even can't remove. So only about 5 Gbyte is free to use for other apps and messages.
Next phone, take one with lots of internal memory, if you like to install other apps.
You can recover photos from cell phone memory with some mobile phone data recovery tool. You may follow this guide that helped me before Mobile Phone Data Recovery Guide
Just remove the SD card and re insert again.
Then make sure you have made back up for your data.
After that type the code below on your mobile screen:
*2767*3855#
This will make hard reset for your mobile ,and you will lose data in your mobile.
After this operation is finished your mobile errors will be fixed 100% and the original firmware of your
mobile will be installed and your mobile will be as you bought it first time.
installed
I have bought new Samsung S3310 mobile. I want to ask that, how to change the default memory to memory card because when I transfer any file through bluetooth it pop ups that phone memory is full please delete something. My memory card is 1 GB. Please help me to solve this problem
All you need to do is go to settings -> phone settings -> PC connections -> select mass storage and save......... Now when you connect the phone to your pc via the data cable, all the necessary installations of usb drivers and such things will complete automatically. You dont need to install any softwares manually. All the installation will occur instantly after you connect (setting of mass storage is very important). The Next Time you connect your mobile to your PC, the memory card on your phone will just act like a pen drive.................... ( I dot use any softwares like samsung pc studio or anything)
i suggest that you save a copy of that important documents that you are mentioning. Save a copy to your PC or flash drives. And as for the memory card, try reformatting it.
You need to format the SD memory card using the camera format function. The manual should tell you how to do this. If you don't have the manual, you can download it from the samsung website.
