Question about Epson FX-2190 9 PIN Matrix Printer
Epson FX2190 - Doesnt move to the beginning of the next page
Hi - when sending multiple pages (1 document) or multiple documents from WORD to this printer - It seems to ride up on every page just a little.
How do I tell the printer to definitely go to the proper begining of the next page every time.
Its stops me from printing all my invoices in a batch mode.
When I hit the tear off button it moves to the right spot for the first 3 or 4 pages after that it loses its thought pattern - H E L P !!
  • 37 Answers
This printer have the option to change the size of paper(the standard long of sheet are 11 inchs, maybe are in 12 or 13), check in you user manual, the size have by default , and if dont the same media size change to the correct size
Posted on Aug 06, 2009
Bothers MCF-490CW 4 in 1 || scanner - when scanning multiple pages, what must I do so when I send as an attachment the attachment is one group instead of each individual sheet?
Create a WORD document then paste each images on a page, save the Word document and then send this Word document as an attachment in your e-mail.
If you do net want to send the Word document then you can create a PDF of the Word document and send the PDF file as an attachment.
Jun 06, 2011 | Office Equipment & Supplies
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
I am trying to fav more than 1 page on my brother mfc-255cw printer but it will not let me. Normally after the first page go thru it ask you if you want to send another page press 1 for yes and 2 for no,...
Press menu *2864 within 3 seconds and the machine will say "maintenance" now press 91 and it will initialise. When it has done this press 99 to exit. Should be ok now.
May 03, 2011 | Office Equipment & Supplies
My Epson CX3810 all-in-one priner does not allow me to scan mulitiple document into one file. Each page is scanned as a seperate document.
The documentation is here: http://files.support.epson.com/htmldocs/cx38__/cx38__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
You can scan multiple pages of a document on the document table and save them as one PDF file on your computer. Epson Scan displays an editing page so you can view the pages as you scan them and reorder, rotate, or delete them as necessary.
Select PDF as the file type setting.
When prompted "scanning complete.  Do you want to continue"  Click "add page"
Feb 28, 2011 | Epson Stylus CX3810 All-In-One InkJet...
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
I have an Epson Office Bx300F - I have a CV of three pages and want to know how to scan the three pages into one scan file Can you advise ? As you imagine having to scan three times means I then have to...
I have a different all-in-one but the tool used for scanning may be similar. When installing the printer, the MF Toolbox utility was also installed. If I want to scan multiple pages into a single document, I have three options for "Save as type". One is "PDF", another is "PDF (Multiple pages)" the third is "PDF (Add page)". I use the second option for multiple pages. Once the first page is done, a dialog box will appear and prompt me to insert the next page in the scanner and continue.
See if the tools installed with your printer have something similar.
Sep 03, 2009 | Computers & Internet
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
Aug 22, 2009 | Epson CX8400 All-In-One InkJet Printer
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
Oct 06, 2008 | Dell Photo 964 All-In-One InkJet Printer
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Epson FX-2190 9 PIN Matrix Printer Logo
174 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
