Question about Toshiba 53H71 53 in. Rear Projection Television
PROJECTION TV Phillips 9P6031c103
I think i have a convergent problem; one day came home and turn the TV the color look all mess up and the sreen was going from small to full screen after a few minutes. I clean the projector bulbs and play around trying to manually fix the colors, all the color seen to be good except is really dark on the picture and when i go to the menue it look realy good. Is just when a movie plays. Please help
    President:
  • 4,402 Answers
This is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Posted on Dec 17, 2007
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
Pusheed in sreen and can't converge red lign
Sounds like the convergence amp Ics are faulty they will distort the picture and you wont have any control over convergening the color back into alignment. Can you post a picture of what your screen looks like?
Jan 19, 2008 | Samsung PCN5425R 54" Rear Projection...
How do i replace my convergance chip
contact parts distributors who sell convergence kits for your model.
Order instruction DVD.
Jun 03, 2010 | Televison & Video
My color wont line up it shows all 3 colors at once on the screen
Replce IC of convergance and check pheriparal componets on the convergence board
Sep 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Televison & Video
Picture double, Color messed up
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 02, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Phillips Magnavox 9P6031C103
You can try ebay, they may have them for auction. or you can try the vendor (philips).
I hope this helps
Shuttle83
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Color is messed up
sounds like bad convergance ic
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
Dec 14, 2007 | Sony KP-46WT500 46" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
