Keyless Albrecht chuck versions for quick and easy drill change;
standard 0-1/8" / 0-3 mm; optional 0-1/16" / 0-1.5 mm.
more details
Best Drill Press For DIY Professionals In 2018
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
