Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I got this epson tx100 somehow when i change new ink it doesn't recognized the cartridge and i bought it genuine epson ink
    Problem Solver:
  • 28 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppn13
Posted on Sep 04, 2009
    President:
  • 627 Answers
You must tell the printer that is new cartridge. By the way when you put the new ink does the printer asking you for the new cartridge.
Also try a deep cleaning too
Posted on Jul 31, 2009
Cant get my ink cartridges to work
This model Epson printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the Epson cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Feb 26, 2013 | Epson Stylus Office Equipment & Supplies
Errcommunication error on epson stylus TX100
If they're Genuine carts, call Epson Tech Support
May 20, 2012 | Epson Office Equipment & Supplies
Epson s20 cannot recognize ink cartridges
have you bought genuine ink cartridge?? if it isnt genuine or original the printer wont recognize it at all..
Jun 02, 2010 | Epson Stylus S20 InkJet Photo Printer...
Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Epson Stylus NX400 InkJet Printer
Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
Aug 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The printer won't recognise the printer cartridges. I tried replacing older cartridges with new ones and even this doesn't work. They are genuine epson cartridges and the same ones I have always bought.
Check chip connnector at ink tank and at head carriage. It's may be dirty. Check status monitor? what ink tank not recognized. Press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
Jun 29, 2009 | Epson Stylus C46 InkJet Printer
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
Nov 08, 2008 | Epson Stylus RX580 InkJet Photo Printer
Cannot recognize ink cartridges
If you are using non genuine Epson carts, then you need to change the carts to genuine ones (full set I'm affraid)
Once you have replaced the carts you should find the error goes away. The problem arises somehow from non genuine carts when one (or more) is inserted that has not been "reset" properly by the refiller. This causes a cascading error through the ink monitoring system and ends up with all your inks going empty one after the other. I've seen this on several models of Epson printer.
The alternative is that the printer has fault on the main board. try the carts first it's the cheapest option. If the nmachine is in warranty, get Epson out to it.
Jul 08, 2008 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
578 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
