Question about Haier HSB03 Compact Refrigerator
Refrigerator is not getting cold and it souns like it is leaking something
I was knocking some of the ice out of the frig and all of a sudden it sounded like I sprung a leak of something.
The problem is that the fridge is in my bar, and I can not take it out to replace it.
Any idea what could have broke on this?
    Scholar:
  • 42 Answers
I have really bad news for you. You have done on of the most famous No No's and that is, you have punctured the evaporator coil allowing all of your refrigerant to leak out. Some claim to be able to patch the evaporator but I have in 30 years only seen couple of repairs done that lasted long enough to justify the expense of doing the repair. Some models have replaceable evaporator coils but this will cost as much or more than to purchase a new appliance. If your frig contains R134a and moisture enters the hole in the evaporator either in drop form or moisture in the air (if the hole is open it will allow moisture into the system) the moisture contaminates the oil in the compressor and throughout the system. I personally do not recommend spending good money to attempt repair.
Sorry but it is true, supertechks
If someone tells you they can repair it and will warranty it for long enough to suit you then make sure you get the warranty IN WRITING, do not fail to get it in writing!
One more thing is it will have to be removed to repair it.
supertechks
Posted on Nov 24, 2007
My LG refrigerator is not cold anymore, what can I do?
And don't forget to check the thermostat. when the motor is running and it is not cooling, think of the cooling fluid, but when the motor is not running think of the thermostat.
Feb 16, 2015 | LG Refrigerators
We bought our frig exactly 6 years ago (to the date!) and suddenly the frig part is cool, but not cold, while the freezer section stay cold and ice is frozen.
Check your freezer section ! Is the coil frozen over ? If so it may have a burnt out defrost element or a bad defrost timer. When the freezer coil freezes over cold air is restricted to the refrigerator section.
Jun 03, 2011 | Refrigerators
Frig not getting cold enough. Freezer section
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | Kenmore 21 cu. ft. Top Freezer...
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
Feb 11, 2010 | LG LRTC19314ST Top Freezer Refrigerator
Ice in frig air vent
you did just fine defrosting it but, when you put everything back in don't overpack it, leave room for the air to circulate. the heat from the bottom unit will cause enough condensation to leak down the air vent and the it will refreeze blocking your vent again
Jul 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Not cold
Hello
I am also having a same problem what i will suggest you youcan see the bucket at the back side of the fridge,switch off ur fridge and turn out that bucket and then turned it back,if it is also not work then the wire is coming to ur fridgger check that wire by tester that the current is coming to that wire or not
This will help you
Thanks & Regards
May 23, 2009 | Kenmore 57029 Side by Side Refrigerator
See if the coils are blocked with ice. Fridge gets cold air from freezer, ice would prevent this thus a warm fridge.
May 10, 2009 | Refrigerators
Frig just not Cold
Check to see if air is blowing into refrigerator compartment.If no air is blowing.It may be that the settings on your dials are not right.If they are and air is not blowing,your evaporator fan is not working,or may be obstructed.
Dec 03, 2007 | Refrigerators
Haier HSB03 Compact Refrigerator Logo
172 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
