Question about Philips FunCam DMVC300K/00 Digital Camera
Funcam connected to pc seeing olnly black image. Mode button not
I have a Funcam web camera, not used for years. I can connect camerea to pc, but seeing only black images. What can I do?
    Master:
    Sergeant:
  • 460 Answers
Try to change the settings in the menu. There are different modes like sepia, ...
Thankyou
Appreciate a good rating from you..
Posted on Jul 31, 2009
I have one intex swc1 web camera but i havenot instalation cd how can i instal web camera
You can try to download the driver from the link below
http://www.dl4all.com/245/tag/web+cam+intex+swc+1+driver.html.html
Thanks for using fixya
Proton
Aug 27, 2011 | Dell Inspiron 14R~ Core i3-350M...
Not working on preview
did you save the pictures into the card and not the cameras memory?
If you plug the card into your pc with a card reader you can have a look inside and also there are file recovery programs available if the card has gotten corrupt but the pictures where saved in it so it can be saved. but if no pictures are saved into the card then tehre is noting to recover,
Jul 07, 2008 | Canon PowerShot SD10 / IXUS I Digital...
Where do i get the driver for my camera fun cam dmvc3ook
Try this link for the Philips FunCam DMVC300K Web Cam.
Make sure you press the right download buttons or you may end up downloading something else.
Thanks for using FixYa.
Apr 13, 2011 | Philips FunCam DMVC300K Webcam
Monitor turns black after 3 seconds
teo6925, "Switch-mode-power-supply" is in partial shutdown mode. Can you see any electrolytic filter capacitors that have a slight "swelling" to their tops? They should be flat!! You may also need to inspect all the soldered component connections very closely for cold, thermally intermittant, "frosty" looking solder joint connections. May need large magnifying glass or 10x to 20x inspection microscope to locate these thermal/vibration "fractures" and then resolder them! If you have a capacitor problem, then you will need to carefully remove and replace with new ones. If you are novice at soldering I suggest that you document your work with digital camera or video tape so you can get everything back together with no "leftover" pieces! Teo, all you need to do to find out how BAD the problem of poorly manufactured capacitors is would be to search WEB for BAD CAPACITORS!!! Look for pic's of ELITE capacitors or CAPXON brand. You will be stunned beyond belief!!! Reading is free!! READ, READ, READ. Let us know what you find and do additional comment here on FIXYA. 12fixlouie
Jan 09, 2010 | BenQ Computers & Internet
I can not view pictures in camera.
You have to have the software installed in your pc.
You have to have the camera in the docking station.
And you have to have the usb cable connected to the pc.
Rob
Feb 28, 2009 | Philips FunCam DMVC300K/00 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Canon powershot a520 problem
Try to see if you can connect the cable to a TV and see if it will do the same thing.
Example: camera - cable plug - to Input of TV.
Jul 23, 2008 | Canon PowerShot A520 Digital Camera
Upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
May 20, 2008 | Samsung NV3 Digital Camera
How can I print multiple images on one page using the direct print feature?
Follow these steps: 1. Connect the camera to the printer. 2. Turn on the printer. 3. Turn the Mode dial to Playback mode and turn the camera on. 4. Press the (+) button on the camera. 5. Press the up or down button, choose Select images, then press the OK button. Note: If you see the message “Use previous print order selection?” select No, then press the OK button. 6. The images display as thumbnails. Select the first photo to print using the < or > button. 7. Select the number of copies to print using the up or down button, press OK. The screen displays the print settings and the number of copies selected. 8. Press the MENU button to return to thumbnails. 9. Repeat steps 6, 7, and 8 to select additional images. 10. After you select all the images to print, press the MENU button. 11. Press the up or down button to select Print an Album. 12. Select the number of photos per page using the < or > button, then press the OK button. Note: To determine the maximum number of images your printer can print per page see the table below. If you select more images per page than the printer supports, the camera will display the error “This function is not available”.
Sep 13, 2005 | Epson PhotoPC L410 Digital Camera
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Philips FunCam DMVC300K/00 Digital Camera Logo
175 people viewed this question
Top Philips Cameras Experts
Are you a Philips Camera Expert? Answer questions, earn points and help others
