Question about The Office Equipment & Supplies
Bin full light stays on and stops shredding and bin is not full
I have a SPL-1506X I was shredding and a piece of plastic accidentally was put through in amongst papers. I pulled what appears to be all of the plastic out But when I go to shred it may take one paper and the light comes on saying the bin is full and it is not
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Piece of shredded plastic may be sticking on the "full" sensor, or switch
Posted on Mar 06, 2018
geemarie
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
  • 35 Answers
SOURCE: Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Posted on Feb 23, 2009
  • 35 Answers
SOURCE: Bin light is staying on
check underneath to see if the bin full flap is working.
First, uplug from power. Look underneath and see if you have a flap. If you do, then make sure it's quiet and move the flap back and forth. You should hear a microswitch click.
If you don't have a flap and the hopper is removeable, make sure hopper is installed properly.
Posted on Feb 24, 2009
  • 215 Answers
SOURCE: The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Posted on Apr 15, 2009
How do I put Staples SPL-770M into automatic mode?
Turn it on and insert a piece of paper you want to shred.
Apr 21, 2015 | Staples Office Equipment & Supplies
The auto stop on my Royal VF850MX paper shredder won't turn off. I was using it and it was fine. Now it won't turn off automatically.
I took my Royal HG120 apart and cleaned it good. Now the auto shutoff works fine. The Royal has 6 screws that I removed (make sure it's unplugged) and then vacuumed it out and then took a q-tip and rubbing alcohol and cleaned the sensors that are located in the middle of where you insert a piece of paper. I was surprised at how much paper was amongst the electrical parts. Perhaps I shouldn't use a bag... just the plastic container. The bag may push paper into place it shouldn't be. I also should empty it more often and not try shoving the paper down to get just a couple more pieces of paper shredded. Good luck!
Apr 03, 2011 | Office Equipment & Supplies
Automatic switch does not shut off after shredding on Staples model SPL-1506X shredder.
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Feb 13, 2011 | Staples SPL1506X (CrossCut) Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Shredder is jammed
hello. follow these steps:
  1. Turn the shredder off at the wall and unplug it. You DO NOT want to be poking round in those sharp blades and have it accidentally switch on!
  2. Take the top off the shredder and place it on a big piece of newspaper, or somewhere you can easily sweep up mess.
  3. Begin by getting a pair of tweezers and taking pieces of paper from one end of the shredding blades. This will loosen it up and give you more room to get the rest out.
  4. Carry on tugging the strips of paper out. It helps if you don't just pull a clump, but wiggle it from side to side. This will get the whole strip out, not just the top.
  5. If any pieces are curled round and you can't free them, cut them with the knife and then tug them out.
  6. Once it's mostly cleared, put the top back on and switch the shredder on. Put it on Reverse mode so it will spit the last bits back up for you to remove.
  7. If it's clear, continue shredding!
[edit] Tips
  • Remember to wiggle the paper, not just pull.
  • Shake it occasionally to get smaller pieces of paper out of the blades.
  • Try not to jam it in the first place (avoid loading a lot of paper or thick sheets of newspaper).
  • Use oil paper or performance oil to lubricate the blades on a regular basis. For an office shredder, medium to heavy usage can require lubrication as often as every three days.
  • To prevent the shredder blades from dulling, remove paper clips and staples before shredding. Shredding CDs and DVDs also cause premature wear & tear. Use the Disc Eraser (www.DiscEraser.com) if you have sensitive discs.
[edit] Warnings
  • Always turn the shredder off at the wall and unplug it! You don't want shredded fingers!
  • Be careful with the blades - they are sharp and you could cut yourself.
[edit] Things You'll Need
  • A pair of tweezers
  • A small, sharp knife
Oct 23, 2009 | Office Equipment & Supplies
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Shredder won't run
I had similar problem. I took unit apart and checked the motor by hotwiring it after checking voltage coming off the circuit board connections that the motor is connected to. Motor did not run until I tapped it a couple times with a hammer. Seems ok now.
Feb 16, 2009 | Office Equipment & Supplies
SPL 1506X Shredder
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
No power to SPL-1506X
I had the same problem-one day the shredder worked, the next day no power. We checked the fuse and it was ok. There is a safety switch that has to engage with a plastic tab on the bin. For some reason it was no longer engaging. We put a piece of cardboard into the slot and now it works fine.
Jan 06, 2008 | Office Depot Ativa DQ60M Shredder
1,088 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Julian Wainwright
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
