Question about Toshiba TEC B-452 Thermal Label Printer
HOW TO PRINT IMAGE BARCODE USING JSP APPLICATION
I AM HAVING IMAGE FILES AS PRN FILE.BUT I UNABLE TO PRINT THROGH SOFTWARE WHICH IS USING JSP .
HOW TO PRINT IMAGE PRN FILE IN THE BARCODE LABEL USING JSP APPLICATION .PLEASE HELP US
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Toshiba TEC Expert
  • 142 Answers
What is jsp
Posted on Jan 14, 2014
5 Suggested Answers
SOURCE: Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Posted on Mar 31, 2009
  • 35 Answers
SOURCE: Hi,
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Posted on Feb 16, 2010
  • 97 Answers
SOURCE: z4m printer problem
You may have an element or two on the left side of the printhead that is worn out and not printing. The best way to see if elements are not working is to use the widest label you have and run the PAUSE test. Turn the printer off, press and hold the PAUSE key while you turn the printer on. Keep pressing for about 10 seconds and then you can let go. When the printer is finished starting up, a test pattern will print. Part of the pattern is a black box. Any elements that are not working will show as white vertical lines. The only way to correct is to replace the printhead.
Hope that helps !
Posted on Jun 09, 2010
  • 54 Answers
SOURCE: I have a px4i label printer. When I print a label,
Check your platen roller for debris, clean with alcohol swab.
Posted on Apr 11, 2011
How to print .prn file
You should have the proper software to send .prn to print.
try downloading from www.nicelabel.cl a Suite version of the software. It's a 3 step setup.
Jun 07, 2014 | SATO CG408 Thermal Label Printer
I have designed a software to print visitor badges on spot for conferences but i am unable to send the print command to my Brother QL-570 Label printer ..I am not able to generate a .prn file .. please...
Welcome to FixYa.
To generate a PRN file, you need to have the printer driver installed in your computer. You should be able to see the PRN option (in some cases, it is termed as 'save to file') in the printer dialog box.
In your own software, you have to use the printers driver as well to produce a PRN file as well.
Since you are also unable to send the print command to your printer, it seems that your printer driver is not present or might have been corrupted.
Download and install the driver for your printer from >>HERE
Thank you for using FixYa, have a great day.
Jas247
Jul 24, 2011 | Brother HL-2040 Laser Printer
I require a .prn file for my cx400 for my software support person to design the barcode string to be used for my software to create the barcodes. my barcode printer is Sato CX400 & the software I am...
HI ...
1.I am using Sato CX400.my printer problem is when i give Command for printing copy (default by prn file one copy) but print out two copy and i wastage lots of label .so please help me about my problem.
2. i have sato Cx400 two printer but in both printer font is Bold & another is UN bold.so how make both printer setting same
Please help me by mail (bvionline@yahoo.co.in)
Thanking You
Jun 21, 2011 | SATO CX400 Thermal Label Printer
I am having trouble printing attachments from e-mails off from my computer.I can get it on the screen,and it shows me how it looks when printed out.I press the ok button and it is saved in a file.From...
.prn files are generated when a user selects the "Print to File" check box in the print window. Make sure that that check box is unchecked. If you are using quick-print, instead of going through the print menu, try going through the print menu to ensure you are not 'printing to file'.
Mar 28, 2011 | Microsoft Windows® Vista® Home Premium...
WANT PRN FILE FOR BARCODE LABEL DESIGN
HOE TO DESIGN A PRN FILE FOR ZEBRA TLP 2844
Jun 03, 2010 | SATO CX400 Thermal Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Printing one line on every other page
I really would need to see a print file to know what is going on.
Set the printer driver to "Print to File", when prompted, name the file "line". The driver will append a .prn to the name.
The resulting file: "line.prn" can then be analysed using any Hex Editor if it is a PCL file or A Postscript error analyser if the job is in Postscript.
Also, fyi - I do not believe you have a simple margin error. But just to make sure, under page setup, make sure that you have the correct page size selected in the driver and the same on the printer.
Don
Jun 25, 2009 | HP LaserJet 4350TN Printer
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
.ear or .war files
There's no easy answer to these as there are too many variables to consider. The first issue is to correct you on one point - HTML and JSP files cannot be made into an "executable file" (like a Windows .exe file) but must be placed onto a web server that can process JSP files.
The most common JSP web server is called Tomcat and can be downloaded for free from http://tomcat.apache.org. This application will allow you to run your project on your local computer or network but it is unlikely (difficult or not possible depending on your ISP) you will be able to make this accessible to other Internet users. This is usually only good for testing to see if your application works properly (which you should do before putting it on the Internet)
If want other people to access your web project you will need to find a commercial hosting provider that allows you to host JSP-based websites. These are actually not so common so you will have to look around the Web to find a good one at a good price.
As far as using Tomcat web server is concerned I would refer you to the manual at the website you downloaded it from. With JSP projects it is not always as easy as copying your files to the server and having it work straight away - sometimes you need other library files and sometimes you need to configure the server correctly with details about your web application - all depending on how you created your JSP project (which I don't know enough about).
If you haven't already, I recommend using the free Netbeans application from http://www.netbeans.org to develop your JSP projects as it makes it much easier, comes with a built in JSP web server and there are a lot of good tutorials and instructions at their website to make it easy to get your web application up and running.
Once you get over the initial problem of how to run JSP web applications, using JSP is a lot of fun and very powerful.
Let me know how you get on or if you need any more help.
Apr 18, 2009 | Computers & Internet
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Toshiba TEC B-452 Thermal Label Printer Logo
357 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
 steve
steve
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
