Question about Cell Phones
Everytime i try to access my ringtones folder, my phone powers down and then turns back on again
Picked up my motorola defy yesterday,how do i tape a song and set it to my ringtone
Create a folder named 'ringtones' (without the quotes) on the root of your memory card, and copy the song you want to set as ringtone to that folder. Then, go to 'Menu > Settings > Sound > Phone ringtone'. The song you copied should be available to be selected.
You can set specific ringtones (sound files you copy to that folder, or any system sounds) to the people in your contact list who happen to call you most. This way you would know whos is calling you without even looking at your phone. Anyway, go to 'Contacts', select the contact entry you want to have his/her specific ringtone changed (you can press the search button and type his/her name), and tap 'Menu > Edit'. Slide to the end of the screen and tap the arrow at the right of 'Additional info'. The arrow will face down. Slide to the end of the screen again, and select 'Ringtone'. After selecting the ringtone, tap 'Save'.
Hope you find these informations useful, somehow.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Apr 09, 2011 | Motorola Mobility Defy Cell Phone
I downloaded a couple of songs to use as ringtones and they are in the correct folder on my card. I set one as my ringtone and called my cell phone from my house phone and it worked. I cut my phone off and...
Just a thought: perhaps your card slot gets disabled whilst in stand-by, as part of the power management procedure. Probably, after you wake your phone up, after a little while, your songs will play as ringtones again. Try to copy them to your phone's internal memory, instead (and delete them from the card, so that they won't show doubled).
Hope it works for you.
Cheers! Carlos
May 15, 2010 | Cell Phones
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Ringtones
you have to format the memory card first to the phone.. easiest way to do this is to take a picture from the phone and transfter it to the card...
at this point the card will now have folders associated with the phone on it..
if you put your sd card into your computer and see any files that are not in a "my_pix, my_flix, my_ringtones etc" folder, drag them to the appropriate folder and you will be able to access them through the phone
so if you wanted to do ringtones drag the music into the ringtones folder. if you wanted music drag it to the music folder
Nov 10, 2009 | Casio G''zOne Type S Cellular Phone
Set mp3 song as ringtone
the message that u see every time is about the phone's memory and  not memory card's . so try reducing the data in the "my files "folder by coping  or moving it to  memory card.   >>> your phone(e 1410 copies  the desired ring tone first to phone . The ring tone can't be set via memory card.
Apr 17, 2009 | Cell Phones
Can't set ringtones that are in my memory card as ringtones!
well if u have internet on your phone you could try buying ONE ringtone and one that ringtone is installed a new folder will come into existance. i think its caled my contestant of something. Anyways, try connecting ure phone to your pc and from then on, all songs u downlaod should become a ringtone if put into that folder. Just a guess though. try it
Mar 29, 2009 | LG RUMOR Cellular Phone
Samsung i616, Ringtone file corrupted
Best way I have found is to use explorer and browse into your mobile device and search for a folder called "volatile". I copied every wierd looking folder that started with XME or such. There were like 999 of them on my phone. Once they were removed, everything went back to normal!
Mar 13, 2009 | Samsung BlackJack Smartphone
Sony ericsson W580i ringtone issues
look into you file folder for the ringtone it will be in there
Oct 24, 2008 | Sony Ericsson W850i Cellular Phone
Ringtones
Did you create a folder for the Ringtones? if you did, make sure you have it on 2 (sounds)...go to Menu, Press 7 (my stuff), press 2(sounds) open your Ringtone folder and Voila!!! der they r...press d options (dont play the song, just highlight d ones u want to set as a ringtone) press 2...n der u go.
Reps are appreciated :)
Nov 28, 2007 | LG Shine KE970 Cellular Phone
Setting ringtone
Here are instructions for setting the ringtone on a Palm Treo 750 running Windows Mobil 6.0 Professional
To change the ringtone do the following:
1.Go to Start and select Settings
2.Select "Sounds and Notifications"
3.Go to the "Notifications" tab listed along the bottom
4.In the Event field either press the middle button or use your stylus to see the drop down menu.
5.From the menu choose whichever option you want to set the ringtone for. i.e. Phone:Known Caller or Phone: Unknown Caller
6. Once you have made your choice go to Ring Type. Here you want to access the drop down menu so you can chose how long the ringtone will sound.
7. Once you have made your choice go to Ring Tone. Access the drop down menu again to cycle through the different types of ringtones. If you have music on your phone you can also choose this as your ringtone instead of having to purchase them but first some steps have to be taken in order for the music to be seen in the drop down menu. I will put that at the bottom of this solution just in case it's needed.
You can use this method to set ringtones for other things such as incoming email, messages and reminders. With Messages Emails, and reminders you can also select music that is already on your phone but I have not been able to do the same with smaller things like "Connection Disconnected".
Here are instructions for making music on your phone into a ringtone.
You may want to have an expansion card for this but it can be done without one. If you are not using an expansion card and would like to make all of the songs on your unit into a ringtone you may have to delete the music files after adding them to your ringtones.
In order to make your music available for choice in ringtone all songs must be in the "My Music" Folder prior to beginning.
Begin by following steps 1. and 2. from above then:
3.Select the "Manage" tab
4.Select Menu then select Add
5. For this part I find using the stylus is simplest. On the top left of the screen push the down arrow found under the words "Select a Sound"
6.From this drop down menu select "My Device" then click on the "Music" Folder
7.Once there Highlight the song you would like to be a ringtone then click "Select"
All done Now the music on you phone is a ringtone. Ringtones made this way can be deleted anytime simply by going into the "Manage" tab again, highlighting the song you wish to delete, Selecting "Menu", Then selecting "Delete"
Nov 22, 2007 | Palm Treo 750v Smartphone
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
