Door stuck closed on a Miele Novotronic W+862!
I've a Miele Novotronic W-862 washing machine and the door is stuck closed with clothes inside!
Big frustration because the door will not open for anything -- plugged in or not.
Can anyone help me?
Thanks so much!
  • 2 more comments
  • djn5915 Aug 02, 2009
    Don't think so but it's full of clothes. :_(
  • craig thorne May 11, 2010
    more info is there water in it
  • Anonymous Mar 14, 2014
    reset miele novotronic w 377
  • Anonymous Mar 29, 2014
    It could be overloaded. The open button is not working. What can I do to unload the clothes?
  • 739 Answers
I'm not sure if you have done this, but open the pump door (the little panel at the bottom left - it opens from the top hinged at the bottom) and slowly drain the machine by unscrewing the large knob inside - do it gently and in small stages or you'll flood the room.
Once you've done that you should be able to open the door by pulling on the orange tab that is also behind the pump door.
Posted on Aug 10, 2009
  • 82 Answers
Does the machine have water in it if so the door will not open check filter
Posted on Aug 02, 2009
Miele washing machine novotronic w505. I did a laundry, just back and found the machine without power / no electricity. It seems and laundry made well. I opened the door handle&clean the filter.
Usuali, there is no fuse inside miele washing machine. One possibility is, that switch for closed door is not working properly. Try to close door with some more force. If that does not help, switch is gone, or something inside on machines "brain"
Dec 03, 2017 | Miele Washing Machines
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
How do i open the filter door for a miele novotronic w526 washing machine?
There should be a plastic tool on the inside of the detergent drawer. It's a flat spatular type tool (mine is bright yellow). Then there is a spot on the little door where the tool fits in and you can use it to gently lever the door open.
Mar 11, 2012 | Miele Novotronic Premier 500 Front Load...
This washing machine makes our cloths smell sour
You need to clean the washer out with this product. Also, be sure to leave the door open between washing's.
Oct 25, 2011 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W 832 washer won't turn on. It suddenly turned off after trying to open the door and now it won't turn back on. I tried switchinging powersources, didn't work.
Make sure the door is properly closed!!! The door opener is electric, and the electrics are turned off unless the door is properly closed, hence with the door closed but not fully "home" you will neither be able to re-open the door nor wash what is in the machine. Just give the door a firm push closed and it should spring to life.
Apr 27, 2011 | Miele Novotronic Premier 500 Front Load...
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
Door will not close
Believe it or not the door sometimes needs to be slammed - try it and see if it works - if not the lock needs to be aligned with the latch
Sep 11, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
544 people viewed this question
Top Washing Machines Experts
