Question about Janome 1017 Mechanical Sewing Machine
Sewing machine not stitching at all
I'm using a Singer Fashion Mate 237, and I can't get a single stitch out on fleece. It was working fine before though. I cleaned my machine and oiled it, changed my needle various times and with various sizes, and it still won't stitch.
It will only stitch when I use the hand wheel and, when the needle is down, roll it backwards and forwards a few times in the same place.
The only thing I can see wrong is my shuttle hook has a lot of little scratches on it. Earlier, I was trying to sew through six layers of fleece, and it would keep making a loud sound. I suppose this is what the loud sound was.
  • Hazuza Aug 03, 2009
    It sounds like a lot, but I only go through that many for an inch or so at once. ^^; I've been making hats like these, and I need to go through that many on the ears; http://fc00.deviantart.com/fs45/f/2009/1...
    I made a couple dozen without problems on a size 14 needle, oddly enough. I've tried size 16, but it hasn't helped since I've had the problem. I'll try to adjust the timing though! Thanks for the link!
  • Hazuza Aug 05, 2009
    Update: Okay, for some reason, it sews mostly fine when the needle is set on the left. When it's centered, it misses nearly all the time, and when it's on the right, it hits the shuttle. The bobbin moves when I set the needle position, so I don't get why it does this.
  • Janome Master
  • 1,388 Answers
SIX Layers !!!!
You really need a size 16 needle that won't bend and miss the hook by the sound of it....can you sew on less challenging thicknesses OK ??
If not, the timing may need adjusting...here is a link to assist:
HERE
Posted on Aug 02, 2009
Computer screen for singer fashion mate 7256 not showing any stitch numbers
Most likely a computer component is failing or has failed.
Oct 23, 2016 | Singer 7256 Sewing Machine
Control Panel shows the following error message: ][ How can I re-set it?
] [ = usually means that your bobbin winder is on. Move the bobbin winder post/shaft from the right position over to the left to switch the mode back to sewing, then try making your stitch selection again.
Jan 12, 2016 | Singer 7256 Fashion Mate Sewing Machine
Singer fashion mate 237
here is a link for part for the machine
Singer 237 Parts
May 02, 2014 | Sewing Machines
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
Nov 04, 2012 | Singer 7258 Sewing Machine
I cannot form any kind of stitch with my Fashion Mate #237. What could be the problem?
Hello:
Check your needle. Make sure it is fully inserted into the needle bar clamp. Also check and clean your bobbin area and under the needle plate and around the feed dogs.
If that doesn't work for you ... get a magnifying glass and check the shuttle hook, needle plate and bobbin for burrs.
Otherwise your machine may be mis-timed and need professional cleaning and adjustments.
Jul 22, 2012 | Singer Sewing Machines
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
Singer 9113 not zigzaging all time when using polar fleece. Have changed needle am using size 11. Most stitches coming out straight. Am making polar fleece socks and when zigzaging the heel it does not...
I am kind of confused as to why it will not zig zag, have you tried moving the needle shaft back and forth after oiling your machine? I was looking at your manual online at Singerco.com and it seems like a very nice machine. I also would try a tear away stabilizer, or good old fashioned gift tissure paper, to see if the feed dogs will get some traction. Other than that, I would call singer at 1-800-4singer and ask for some other solutions. I am hoping that it is a free fix.
Nov 04, 2010 | Singer Sewing Machines
How do I reverse stitch on a singer 362 fashion mate model
The large knob in the center of the stitch length dial is a button, push it in to reverse stitch. Hold in as long as you need to reverse stitch, then release to resume regular stitching.
Jan 09, 2010 | Singer Sewing Machines
Janome 1017 Mechanical Sewing Machine Logo
1,004 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
