Question about Whirlpool Refrigerators
Refrigerator not making ice/freezing stuff - Whirlpool Refrigerators
    Novelist:
  • 129 Answers
Hi..
In this problem you need to check this parts
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.Good luck.
ICmanServer
Posted on Jul 31, 2009
Why is my GE side by side freezer not freezing on top?
It sounds like the freezer fan has failed. You are correct on the ice machine.
Jul 21, 2014 | General Electric GE Profile PSDS3YGXSS...
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
Dear Help 'Desk, I have a Samsung silver nano fridge/freezer. I've broken one of the removable door shelves in the freezer. Can you suggest a suitable (preferably clear) glue to repair the
Fevi-quick stick fast glue will be useful.It will take few minutes to hold the broken parts.Dont put overload of food stuff on the rejoined tray.But it will hold the basic load.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Bottom freezer "on" but not freezing and not making ice
Refrigerator running but not that cold, freezer running also but not freezing at all. Also not making Ice
May 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
No ice or slow ice
The more "frozen items" in the freezer, the less of an impact the introduction of a non-frozen item (water in ice maker) will have. Hence a freezer full of frozen item will freeze water faster than a empty freezer but the difference would be negligible.
clarkco
Mar 05, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Ice Maker works but
the white stuff is hard water minerals that are in your water. they get concentrated when water freezes. try a good quality water filter.
Nov 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
