Question about Simplex Kaba Ilco Unican 1000 keyless lock
Lost the code 0f kaba ilco unican 7000 serial novj139906 need to set new code aidan
5 Suggested Answers
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 963 Answers
SOURCE: I have a Simplex Kaba
I believe you can find this to be relevant:
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: We are trying to recode
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
SOURCE: How to reset codes in Kaba ilco Unican 4000 access control
The factory-default master code for Unican 4000 is 12345678
Posted on Mar 08, 2011
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
I work in care home where we use unican 7000 series to lock our office. One of our service users know the code so I tried to find instructions of how to change the code.
This page will show you a grid; go across from the "7000" to the rightmost column "TIPS" and click on PDF there. The download for changing the code will appear.
This is a PDF file, requiring Adobe Reader is installed on your computer to open. There is a link on the same page to download Adobe reader if the file will not display for you.
Aug 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How can I put a new code in a unican 7000 when I dont know the original code
Go to the grid that the highlighted link above takes you to, then go to the far-right column for 7000/7100 " Tips" and click on PDF, which will download the PDF file of the reprogramming instructions that you need. Again, you will need Adobe reader to view this file.
Jul 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Ilco unican- USA We would like to receive the standard code, which it has when you purchase this safe
Jun 27, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Lost combination on the unican 1000! How do i get it back or set a new number in it?
I will give you several sources of information for you to pursue.
First is a link to a chart where you can download PDF files for your lock ( the L1000):
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=l1000
There is a link on that page where you can download and install Adobe Reader in order to open and view PDF files, if you don'ta already have it installed on your computer.
Aditionally, here is a link to a website wherein it is described how to change the combination on the unican lock:
http://www.lilocksmith.com/keyless_Locks/unican1000.htm
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Unican LL1011 lock - the code opens the lock correctly. If a wrong button(s) is pressed the lock does not open as I would expect but when the correct code is entered it then fails to open
I recommend that you contact Kaba Ilco with this problem--there may be nothing wrong with it at all, but you need an answer.
Jan 28, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Bought a house with a Unican 7000 series keyless lock on it. I have the current code but want to change it. Can someone tell me how I can change the code?
Yow will find a link to download the manual for your model on this page:
Oct 30, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
We are trying to recode our simplex 7000 unican ilco lock (5 button). can you send instructions
Sep 08, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
512 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
