Question about Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT
Laptop keyboard "dropping" key strokes
My Dell Inspiron keyboard is malfunctioning - it randomly does not register letters as I strike the key. It happens randomly and on any key. I then have to go back and "fill in the gaps" - hope that makes sense!
I am guessing that it is terminal, but hoping otherwise. I'd be grateful for any advice!
Thanks
Gayle
  • 19,396 Answers
If this happens always with same key, then it is usually a bad key switch, and keyboard must be replaced.
If this happens randomly on a set of keys, then the keyboard flat ribbon cable is not well connected or is faulty, or the keyboard is faulty.
The laptop must be taken apart to check the keyboard connection.
The keyboard on dell is accessed removing determined screws underneath, then removing the upper cover that enclose pad and armrest.
If the keyboard is well connected, and fixing connector does not solve the problem, then the keyboard must be replaced.
Posted on Jul 31, 2009
My dell inspiron duo keeps posting a random "r" key when I type
your laptop keyboard ( R) letter key is stuck so the only option is to replace the keyboard .
Sep 03, 2013 | Dell Computers & Internet
I have a new Dell Inspiron laptop, windows7 and, randomly, keys do not register on the page especially in e mail.its not often its the same keys and none of them are actually sticking, just not connecting
Hi There,
If the laptop is new, it's still under warranty and you should simply call Dell and have them replace the keyboard. It's definitely not a software issue. Batches of parts which are mass produced are always going to have a few defective ones, and you have merely been unfortunate to get one of those; your keyboard.
Go online to Dell Support and find the Warranty link. When there, enter your Service Tag # (found on the bottom of your laptop on a slender label) and use their Chat service to get in a chat with a tech rep. They will advise you on your warranty type and what you need to do to have them replace the keyboard.
Although it's also possible to buy a replacement keyboard online at eBay and do it yourself from the online Service Manual for your machine (and really easy), you will void your warranty by doing so.
Best of luck.
Jul 14, 2010 | Dell Inspiron 1545 Notebook
Dell Keyboard/Mouse Lag
Check your ease of access settings from the control panel. Make sure you don't have any keyboard and mouse settings that make for slow stroke response.
Mar 31, 2010 | Dell 0Y3740 Keyboard
My dell xps m140 keyboard is making double letters
Letters may be sticky. Did you drop coffee, soda or any liquid on the keyboard? Does the letter key "stick" and come up a second after you release it?
You may need to clean or replace the keyboard. To be on the safe side BEFORE you do it, plug a full size keyboard on the back of your laptop and check if the problem goes away.
Mar 21, 2010 | Dell Inspiron XPS M140 Notebook
I have a Dell Inspiron laptop, and certain letter
This could be a possible hardware issue. You can try to use an external USB keyboard and check if the keys are working or not. If you do not have an external keyboard, you can try to use the onscreen keyboard. To do this, go to start>programs>accessories> accessiblity and then choose on-screen keyboard. Open a notepad and try to use the keys which are not working using the onscreen keyboard. If onscreen keyboard works fine , then you need to get the keyboard replaced.
Nov 11, 2009 | Computers & Internet
I have a dell inspiron 1545 and the keys randomly don't work. I will type and letters will not work unless you press really hard! Very frustrating, waht to do?
Generally, the best resolution is replace the keyboard. Simple process and keyboards are usually available on EBay for less than $40
Sep 27, 2009 | Dell Inspiron 1545 Notebook
Keyboard letters opkbnm not working on dell inspiron laptop,
Sounds like keyboard failure, replacement keyboards are around $20 on Ebay
Jun 23, 2009 | Computers & Internet
Dell inspiron 1300 laptop
There are individual tiny switches under each letter. When the letter is pressed it sends an electrical signal to the keyboard controller and the CPU to register which key was pressed. Liquid under the keys will short out the switch so it does not send out the signal any longer. You need to get it repaired by the manufacturer or local PC repair shop.
Don't forget to rate this solution.
Jan 11, 2009 | Dell Inspiron 1300 Notebook
Keyboard Malfunction
Does the laptop have a touch pad type mouse device on it? If so, you might accidently be hiting the touch pad with the sides of your palms or thumbs while you are typing a document.
Nov 10, 2008 | Dell Inspiron E1505 Notebook
Broken keyboard
To start you can temporarily use an external USB corded keyboard, do not use a wireless keyboard, a corded usb keyboard won't require drivers, and you can access the system straigh away. You can buy a wired usb keyboard at any computer shop for $20/$30.
After you access to your system using your external keyboard, do a backup of your data, and have laptop internal keyboard replaced. The spare is not expensive, but the job should be done by a technician, here is the replacement part: Laptop keyboard replacement for Dell Inspiron E1405
Oct 05, 2008 | Computers & Internet
Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
611 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
