Question about Cell Phones
LG PC suite 3
I`m having great difficuly in connecting to my KU990i.  Do I need MS Outlook to be installed? If I read it correctly, that is where files are found. thanks in advance
I want to download stuff from my lg ku990i onto my computer but didn't have a disc and there are so many companies offering downloads but don't know which one to use
Hello thanks for using fixya
To transfer stuff from Lg ku990i to your computer, Download its PC suit. By connecting your cell through PC suit. You can easily transfer your stuff to the computer
Downloading will automatically start after clicking on it. Download it then extract the files & install it on your PC.
If downloading is not start automatically the folloe the direct web link to download it, In this case
"click here"
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 25, 2011 | LG KU990i Cell Phone
My laptop can't recognize my Ku990i and after installing pc suite it say's that can't recognize mobile device and the connection failed. what to do?
PC suite application is only for Nokia handsets it never detects any other mobiles. Goto this site and install LG pc suite click here
Jul 30, 2010 | LG KU990 Viewty
Connecting LG KU990i phone t
try this..
1. open LG PC suite, connect your phone to PC,let the PC suite find your phone..
2. open your device manager and check if there is an exclamation mark beside the devices listed there including your phone.
3. once you find it, right click that device, select update driver,select yes this time only.
4. don't select install the software automatically, select '' install from a list on a specific location'', click next.
5. tick the search for the best driver on these location.
6. untick search from removable or floopy, tick include this location on the search,
7. click browse and point out the windows to the folder where your programs was installed by default, C:\Program files\LG PC Suite\drivers
hope this will help you.
Feb 20, 2010 | LG KU990 Viewty
How do I get my photos from KU990i to my laptop
Install on the laptop the software LG PC Suite. After this, you have to connect the phone to the laptop through USB cable. the laptop will detect the phone, will install the modem (phone modem) and then you open Lg PC Suite program.
Oct 27, 2009 | LG KU990 Viewty
LG Viewty pc connection problems
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Dec 30, 2008 | LG KU990 Viewty
Can not connect KU990 to PC through USB
The CD that comes in the pack is does not work on Windows Vista. if you do not have Windows Vista, try to add the LG suite into your firewall (if you have one). You do that by goin into control panel and selceting firwall. Once done that go into setting then expectaions and then add a program. hope this helps.
Oct 11, 2008 | LG KU990 Viewty
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
Cell Phones Logo
116 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
