Question about Mustek PVR-H140 Digital Media Player
Hi I need to replace hard drive on my Mustek PVR-H140
Hi they told you to swap the hard drive but how do you copy the firmware onto the new drive windows wont let you copy the folder
Posted on May 03, 2010
3 Suggested Answers
SOURCE: mustek pvr h140
yeah, man, i did the same. cracked the glass, without damage to the screen, and then just made one myself, cutting it out from a cd-box and then glued it on :)
Posted on May 13, 2008
  • 4 Answers
SOURCE: HOW TO CHANGE THE MUSTEK PVR-H140 BETTERY
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
Posted on Jan 17, 2009
AC power jack came loose from the board on both the Yukai PVR-H240 and Mustek PVR-H140. Is this a common problem?
This happened to me too. Just unscrew the 4 screws, lift out the hard drive and glue it back down to where it was (2 little pegs will fit into two little holes on the circuit board. You can touch the contacts with a thin tipped soldering iron if you want to but you probably don't need to.Then close it up. That worked for me!
Aug 23, 2009 | Mustek PVR-H140 Digital Media Player
I hope this helps,
Dec 06, 2008 | Mustek PVR-H140 Digital Media Player
NEED DRIVERS FOR MUSTEK PVR-H140
HI,
the drivers for the unit are available at http://www.nodevice.com/driver/_PVR-H140/get33981.html
you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
G.
Jul 12, 2008 | Mustek PVR-H140 Digital Media Player
My mustek pvr-H140 freezing
Tje pvr-h140 basicall have 3 major components
1- 40 gb hard disk
2- battery pack similiar to the cordless phone battery packs
3- integrated panel with LCD and control buttons; usb port; power port; av in/out port.
when the unit hangs on initialize; this mean the hard disk is not responding. you can hit the recessed reset button and and power it back on. if the hard disk is OK this should clear up the issue.
if the hard disk is bad (crashed) then you need to replace the disk. Usually a fitjitsu 40GB notebook drive
also if the unit was dropped; constantly banged; etc then the cable to the hard disk to the integrated panel may be loose. The disk to cable is pinned and doesn't come loose but the other end of the cable is taped to the integrated panel and can come loose if the unit is not handled properly.
finally if the boot up files are corrupt; then you should be able to see it on the pc with the usb connection.
In this case you need to download and restore the files as discussed in the other solutions. Basically mustek has a website with all the drivers.
Jun 18, 2008 | Mustek PVR-H140 Digital Media Player
Frozen in "Initalize"
you need to go to musteks website and download the following file pvr-h140_restore_files.zip from product support area
that should get your pvr working again ?.
link to support page
http://www.mustek.com/mustek/supportdrivers.php
Apr 08, 2008 | Mustek PVR-H140 Digital Media Player
Mustek PVR
Try Maplins, or a specialist electronic component supplier.
Apr 07, 2008 | Mustek PVR-H140 Digital Media Player
Mustek pvr h140
Feb 18, 2008 | Mustek PVR-H140 Digital Media Player
PVR-H140 doesn't work but cannot restore files
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
Nov 10, 2007 | Mustek PVR-H140 Digital Media Player
Mustek PVR-H140 Digital Media Player Logo
176 people viewed this question
Top Mustek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
