SOURCE: LOGITECH FORMULA VIBRATION FEEDBACK WHEEL FOR MAC
Hey i need help. My wheel don´t work on my windows
SOURCE: Connecting SRS-BTM30 bluetooth speakers to my vista laptop
This has also been sending me around the bend. I resolved it by disabling the speakers on my laptop. To do this go into control panel, then hardware and sound, then change system sound. Select your speakers and disable them. This allowed me to play music through the speakers. You can also re-enable the laptop speakers after this.
SOURCE: can't upload from LG KU990 to my mac
Bluetooth seems to work for both up and downloading. For uploading make sure the two devices recognise each other. Then select the file in the appropriate KU990 folder. Click in the little text box on the bottom left. Select Send then choose bluetooth and your target, which should be your bluetooth equipped mac. To download to the KU990 from Mac select send file in the blue tooth icon menu and proceed logically.
SOURCE: IBM T43 Bluetooth not working
Press Fn+F5 then push "Turn On. Now your bluetooth device is turned on, connected and working. :P
Select the "Bluetooth" icon from the Today screen of your iPAQ h1940. Click on "Bluetooth Settings." Touch the "Turn on" button.
Select the "Accessibility" tab from the Bluetooth menu and select "Allow other devices to connect" and "All devices." Click "OK."
Click on the Bluetooth icon in the upper right-hand corner of your Mac. Click "Turn Bluetooth On."
Select "Set up Bluetooth Device" from the Bluetooth menu and click "Continue." Select "Any Device" and click "Continue."
Select your iPAQ h1940 from the list of devices and click "Continue." Input the passkey number from your Mac into your iPAQ.
Select the type of syncs you want with your iPAQ and Mac and click "Continue."
Select "Browse Device" from the Bluetooth menu on your Mac and select the iPAQ from the list. Click "Browse."
Add or remove files from your iPAQ h1940 by clicking on them and dragging them into a file on your iPAQ or on your Mac. Close the window when you are finished and select "Turn Bluetooth off" from the Bluetooth menu.
Click "Turn off" on the Bluetooth icon on your iPAQ h1940.
