Question about Avastor Computers & Internet
Avastor/SDX/500GB will not mount. Solid Red light. How do we fix?
Pt cruiser 2002 Alarm red light solid on
Your alarm is ]n valet mode. If your led is pod mounted there is a button in back of it. If your led is hard mounted in the dash, you'll have a hidden switch usually mounted on the kick panel or under dash. Either way, turn on ur ignition push the button turn off the key, your led should go out. Hope that helps.
Dec 28, 2016 | Cars & Trucks
Why would gould water pump red trouble light indicator come on when power switch turned back on after having been off for a few hours? Had to turn off power to pump earlier in day due to volatile elec
check and prime the pump as the light may indicate no water and so the pump will not run
foot valves leak back the water so it may need priming again
Jul 21, 2017 | Cars & Trucks
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
When i press the mike two red lights are coming on end the reception isn't good how do i fix this problem
Green changing to Red it normal operation from receive to transmit.
However the ant light should not light it is to indicate the SWR= standing wave ratio.This does not normally indicate any reduction in you ability to receive signal it only refers to reflected power from you antenna system to your receiver/cb. You may have a insulator in the wrong location. If it is an solid mirror or body mount the mount must be grounded with no insulator on coax side and an insulator on the antenna top of mount antenna must not be grounded.
If you have a coax that is damaged and i mean even bend from pasting thru a door or other "pinch point" it may be bad.
http://www.firestik.com/Meas-SWR.htm
Sep 16, 2011 | Cobra 29 LTD CB Radio
Fantom 120 gb external usb harddrive
Make sure you are using the right power unit, or the power unit is working.
May 13, 2009 | Fantom Drives 120 GB Hard Drive
500 gB doesn't respond to anything!
Leave it unplugged for a minute or so and see if it boots up.
Check the Power supply if it still works.
Aug 21, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
102 people viewed this question
Top Avastor Computers & Internet Experts
David Payne
David Payne
Are you an Avastor Computer and Internet Expert? Answer questions, earn points and help others
