Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
Mother board problem@ monitor & ram is ok but no display in monitor
  • 89 Answers
Check whether the cable is write if it is ok then press del key while the system is booting
Posted on Jul 31, 2009
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Thanks...
Oct 09, 2013 | LG 700M 17" CRT Monitor
Hp pavilion slimline x3507c pc. when I boot up the monitor remains in standby mode. I have already determined that the problem is in the computer not the monitor. The power supply is good, the fans run,...
very simple bring a new AGP card and plug in it on your pc and plug the monitor pin in new agp now start your computer . monitor will turned on.
if the monitor is not turned on its mean your have problem in your ram or mother board for that pluged out your all rams from your pc and start your computer if cpu ring a beep its mean you have ram problem and the mother board is ok but if you cant hear any beep its mean mother board's problem ram is ok.
Jul 16, 2011 | HP Pavilion Slimline s3700f PC Desktop
My computer cant display anything but it normally comes on as usuall
after switching on everything check backside of your system (cabinet) - fan must be running normally - if it is running slowly or if it is not at all running then SMPS is deffective - IF FAN IS RUNNING NORMALLY THEN .....switch off everything - remove monitor's cable from system (cabinet ) & then switch on only monitor - then you will get ''no signal '' or some display or some colour on monitor - that means your monitor is ok & problem is with system - if you don't get anything then your monitor is deffective - IF MONITOR IS ALSO OK THEN.....switch off everything ....open cabinet's cover ...observe carefully ...on main board 1 cell (round shape)will be there - remove it & check its voltage using multimeter ...it should be atleast 2V & above ....maximum it will be around 3.2 V - if it is not ok then replace it ....IF CELL IS ALSO OK THEN ....remove RAM & re insert (in same slot or another slot)......then switch on .....if it works ok otherwise for testing purpose bring same type of RAM & fix it & check......if it works ok then RAM is deffective OTHERWISE ......there is a problem in main board................if you are using display card (graphics card ) then remove it & reinsert on another slot .....also observe on graphics card whether any capacitors are blown ......on main board also observe whether any capacitors are blown.....if possible for testing purpose bring 1 graphics card & check it ......technical person can do all these things easily ....for non technical person it is difficult............so if you can do ....try it otherwise call service engineer................iam babu - service engineer (computers, laptops, printers, etc..) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com ....
Apr 13, 2011 | Dell Dimension 2400 PC Desktop
No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Jul 21, 2010 | Intel Desktop Board D845WN Motherboard
No ram beep is ok but there is no display
pls. replace with a new same rating RAM
Apr 06, 2010 | Intel Motherboard
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD and no display is comming
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD I cant see any display on my screen when i turn on my computer. But it looks it has read all the information from harddisk and loaded the operating system. but on screen i cant see any raster i.e. display.
First At this time u observe one thing check the Numlock Status if it is ON/OFF (Glow ) in Keyboard when u pressing the  Numlock key, the system is giving display check with pci vga card.
If not u  remove the Ram module and heard the Beepsound,if Beep is comming Clean the Ram & Ram slot the try it again
If not check with another Ram module.
If it is also not problem u clear the CMOS once and check it
Jan 22, 2008 | Computers & Internet
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
