Question about Proform 730 Folding Treadmill Model PFTL71104 - !
Proform 730i speed not working
I input my key and the console has all its lights but when I push the button for a speed it will not move. It won't even make the beeping noise that you usually get when you press a button.The only buttons that are working are the Stop key and the Jog button on the quick programs side but when I press start nothing happens.I checked the sensor and the magnet to make sure it was 1/8" away from magnet.I bought a new motor control board and that does not work either.Please help! My treadmill is only 3 yrs old, and my warranty expired.
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
  • 3 Answers
SOURCE: Proform 730i powers on but will not move when I input speed.
I had the same problem-only one of my programs would work, and the rest of the buttons (even start) would not work. I used some scissors and carefully cut about a 1/2 inch in the plastic inbetween each of the copper strips in the ribbon cable. Then I seated each one individually (put them back in the white plastic thing) until I found the one that was freezing all of the other buttons up. Now all of my buttons EXCEPT for the one that was working before work. I can live without 1 program if it saves me $300
Posted on Aug 23, 2010
  • 84 Answers
SOURCE: The board lights up, but
i think your console is shot check connections on the controller board. when pressing buttons, and some commands or none work, its the console
Posted on Feb 28, 2011
ercupa190
  • 12223 Answers
SOURCE: Console
Dear Sir:
See the diagram attached for Reed switch, clean, tight the connector very well.
2) Change batteries by new ones, and clean the contact very well!
sincerely. God bless you
Posted on Apr 26, 2012
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Is there a reset button on proform 730i
Yes there are reset button to side the main swithc. is the breaker.
You must shure that it doesnot another electrical and electronic problem.
sincerely.
Nov 10, 2011 | Exercise & Fitness
Changing proform xp185u from km/h to mph
Follow the next step:
    • 1
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
    • 2
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
    • 3
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.
sincerely. God bless you.
E.CUADRA MANAGUA, NICARAGUA. C.A
Oct 26, 2011 | Exercise & Fitness
The board lights up, but when you attempt to push a button (speed, program select) nothing happens. I do however have the stop and pace button beeping 3 times when you touch, but nothing works.
Feb 28, 2011 | Proform Exercise & Fitness
Proform Sport 1000 - The right hand side of my controls which allow me to change the speed of the treadmill do not work. The left side is still operational and allows me to change the incline and select...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Aug 09, 2010 | Proform Sport 1000 Folding Treadmill...
My control board does not work...buttons cant be pressed to engage the treadmill? I have a Pro-Form cross walk>
Jul 21, 2010 | Proform Crosswalk 500 Treadmill
Proform treadmill doesnt work
May 26, 2010 | Proform Perspective Es Treadmill PFTL99806
Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Apr 14, 2009 | Proform CrossTrainer Treadmill
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
Mar 19, 2009 | Proform 730 Folding Treadmill Model...
Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
187 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
