Question about Car Audio & Video
1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
I have a 1993 Toyota (Camry) Vienta Ultima. It has its standard ''Fujitsu Ten'' radio/cassette/12 stack CD player.
Recently the CD player has stopped working. When I go to select the CD function the display shows the code ''INF4'' and does nothing else, I can't even remove the CDs from the stacker in the boot (the cartridge ejection no longer functions)
Any ideas?
I had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
Posted on Feb 21, 2010
What causes a 1993 toyota vienta to heat up excessively
Coolant level low, thermostat stuck closed, radiator fans failed, head gasket leak to coolant jacket
After checking the coolant level, look at the radiator fans when it is very hot to see if they operate.
If OK, have a mechanic do a simple check for combustion gases in the coolant, and a compression check on all cylinders. This is not expensive.
If OK, change the thermostat and flush the radiator.
May 31, 2014 | 1993 Toyota Camry V6
95 Vienta 3VZ FE misses on acceleration. New plugs fitted
run fault codes as the miss may be injector problems and not plugs.
Dec 07, 2013 | 1990 Toyota Camry
Can't figure out how to change the time on the Fujitsu Ten am/fm cassette player in a 90-something model Toyota Camry. Please help!!!
You hold down mode button for 3 seconds then use selector knob to select time ,then adjust time to suit
If you need to turn demo mode off hold down mode button for 3 seconds ,select demo then turn knob to off
Feb 15, 2013 | Car Audio & Video
We have recently purchased a 1993 Toyota Camry Ultima and we can't get the CD stacker to work. One of the wires has melted. An orange one with a plastic base. Any suggestions as to where we can ge
burnt wires mean excessive current or dead short. your unit is not fuse protected so I would say that a new unit may be the cheaper option
Jan 09, 2013 | Cars & Trucks
The vehicle badly steps out on the rear when going over a bump on the road, excessive sideways movement. can i change the rear wheel bearings and how? The vehicle is a 1994 camry V6 vienta ultima with abs...
There is a "stablizer bar" That runs from wheel to wheel under car. Make sure that is not broken. I saw it happen to my buddies honda once. Felt just like what you are describing
Mar 02, 2011 | Toyota Camry Cars & Trucks
Hey Toyota Ed, I've seen that you have helped people unlock their Fujitsu Ten radios after the HLP code has appeared. I have a 1995 Camry Vienta with a Fujitsu Ten cassette deck that I have locked to the...
HLP means request Help Code
When the display shows HLP (Help), you need reprogram the EEPROM, with a memory Programmer Eeproms.
I hope that helpfull to solve it.
Nov 10, 2010 | Car Audio & Video
1997 Camry Vienta 3.0 litre revs high at startup
To give you a simple answer, no. My advice is to take it to an A level technician for diagnostics. Sounds like you could have some sensors misreading.
May 30, 2010 | 1997 Toyota Camry
I am trying to locate another remote for my 1993 Camry Ultima
Best place to look is on ebay. Find a reputabe seller, be sure to match the FCC ID number on the back of your current key to ensure compatability. You can probably get one through a local Toyota dealer but will cost much more.
May 09, 2010 | 1993 Toyota Camry V6
Transmission Staying in 3rd Gear.
if the car is worth the amount of money they want to change the transmission then yes if not no i would not pay no more than a 1,000 on it the car is not worth it
Jun 18, 2008 | 1993 Toyota Camry V6
Toyota camry 1993 model- fujitsu car radio
You are going to have to remove the center console, remove the screws, this should make the dash screws visible. Remove those. You'll have bolts on the bottom of your dash, below your steering wheel. Remove those. There'll be screws underneath that remove them. You should have clips all the way across your dash. You'll have to probably remove any knobs on your dash. But your whole left side dash will have to be removed. If you are uncomfortable with this; please consult car audio dealer for help. Once you have your dash removed, unclip your wires running to your dash lights. You should be able to pry the center of your dash off now. Find the screws holding your radio in. Now you should be able to replace your radio. Let me know if you have any further issues...
Apr 09, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Car Audio & Video Logo
495 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
