Question about Cell Phones
Phone went off settings went wrong date time etc got it back on and it was in bluetooth mode, now no sound at all bluetooth off.
I am trying to pair my Plantronics Explorer 220 ear piece to my samsung At&t cell phone, It can not find the passcode # 0000,1111,9999 or 1234. Is there another code i can use?
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
SETTINGS
Time and Date
Phone Settings
Bluetooth
Sound Settings
Network Services
Security
Reset Settings
BLUETOOTH
Discover/
Search
BLUETOOTH
220Plantronics
Headset Passkey
PASSKEY
0000
Step Two:
Prepare Headset-
Pairing Mode
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue.
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with
another device, follow pairing instructions on the next page.
Apr 20, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Have no sound when paired to my phone but when I pair it to my sons phone it works fine. what am i doing wrong
You didn't list your phone model so I can only give you basic directions. You'll need to check the bluetooth settings under the bluetooth menu, usually found in phone settings. The mode you're looking for is handsfree device or something similar (not headset).
Feb 16, 2010 | VXI Corporation Blueparrott B250-XT...
Setting date/time
The time and date can always be set or changed in the setup mode. Just turn the camera off and back on, then try again.
Sep 03, 2009 | Kodak EASYSHARE M1063 Digital Camera
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Setting Date And Time
By Settings/Time and Date switch Time zone updating to Manual Only. Now you can set time and date below
May 31, 2009 | Samsung S8300 Ultra Touch platinium-red...
My LG voyager will not pair with the motorola h710... anything to fix this?
I have heard that some bluetooth will not pair with every phone but I don't know how true that is. I will check in 2 that and get back 2 u. I had a hard time pairing my bluetooth with my voyager I had 2 put both the phone and the bluetooth in discovery mode. I had to hold the power button on my bluetooth for about 30 sec till it went into discovery mode.
Mar 15, 2009 | LG VOYAGER VX10000 Cellular Phone
Bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Sep 16, 2008 | Plantronics Explorer 220 Bluetooth Headset...
I need to know how to connect my jabra bt4051 headset to my phone. lost the instructions
I recently lost the instructions to one of my bluetooth also. What I did was this.. I went to the bluetooth link settings and turned the POWER on under SETUP. I then turned on my bluetooth and pressed the button (holding it down) until it was a solid light. I then went back to the bluetooth settings and clicked on FIND ME. If the bluetooth is in the correct mode your phone will discover it and will add it to your cell phone, it will also change the solid light to flashing. Flashing says it is on/activated. I hope this has been helpful.
Jul 11, 2008 | Cell Phones
Time and date
I'm almost positive there's nothing wrong with your phone "ssandra". You set the day/time/year etc. on the base (answering machine) separately from the handset . . . you press a series of buttons. I've done it several times, but now after a move I can't remember how you do it, and I can't find the instructions I had. That's actually why I was on this forum (looking for the instructions). Since you posted your question last year, this probably can't help you now. But I thought I'd answer anyway . . .
Dec 14, 2007 | Panasonic KX-TG5632 Phone
Cell Phones Logo
49 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
