Question about Compaq Presario 5000 PC Desktop
I'm using a Compaq presario CQ40-310U. Last night after accepting windows update, i saw dotted white lines at the bottom of the taskbar/display panel. What has caused this? What should i do to remove it?
  • Compaq Master
  • 3,051 Answers
Hello there
if yougo back to your updates and look to see if there has been a update for your video or somthing like this try to change the resolution on the screen and see what happnes then shut down the computer and restart if it is still doing it upon start up than i would remove the update to see if this has caused the problem
Posted on Jul 31, 2009
  • bayou sam Jul 24, 2011
    This is a well known problem with this (and related) HP series notebooks. Only solution appears to be LCD replacement. But then problem recurs. Personally, I suspect something to do with hinges straining the bottom of the LCD panel, or the wiring loom between mainboard and panel.
    http://h30434.www3.hp.com/t5/Notebook-Di...
    President:
  • 1,884 Answers
Firstly put the auto update feature OFF. All updates are not for you. And if you have to use updates do them one by one with your blessings. If you leave it to the computer you will have so much junk on your computer that it will slow down as everything has to be read before you can start using it. To undo it, restore the PC to an earlier date. It will use updates only upto that date and not the fresh ones.
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
My compaq presario wont let me see my tabs, it will not show if i bring thre mouse to the bottome
By tabs, I assume you mean "taskbar". On your keyboard is the windows flag....between Ctrl & Alt. Hitting that should make the taskbar pop up.
You can then change your settings to keep the taskbar always visible.
If you taskbar is not longer on the bottom (on the side), click & drag it to the bottom.
Oct 11, 2013 | Compaq Computers & Internet
Black screen with flashing horizontal lines
it can be the fibre or someone pressed the screen on the topside or plced something heavy on it
Apr 14, 2017 | Compaq Presario C700 Series Laptop...
My recently purchased used Compaq Presario V2665US notebook has a horizontal white line at the bottom of the screen below the windows Taskbar. The line actually cuts into the bottom of the Taskbar a...
the old dog Presairo. id buy something newer, sure would
2005 carbon dated by me? 12 years old now,
buy a used LT at Goodwill with Coa sticker with W7 on it.
and never any compaqs unless 2010 to 2013(last year made 13)
the best PC is one that is supported in 2017
and has future.
and not buying parts that cost 2 to 10 times
what yours is worth. right?
Time to upgrade, its not hard, the USA is in glut status in used PC. (vast numbers are scrapped here)
or sent to 3rd world. (on ships)
why post not telling the OS (oper.. system?) making answers 10 time more hard.> why?
no photos of said lines, pretty hard to tell in words what a complex screen shows. no? my guess is the screen is bad.
that is why you found it for nothing (hope) and 50 to $100 fix plus labor.
this no monitor, its Laptop screen so there are NO size buttons.
right click the screen desktop see those choices, that is all you get.
or control panel click display ,wysiwyg.
the lines,
if you gently twist the screen with 2 hands, do the lines change
i bet yes, telling you what?, "bad screen"
if you plug in a Desktop VGA screen to the rear.
then push FN+F4 key and pick external or both , bingo
you get that external screen working and now it works , right?
this PC is now listed as retired at HP
best is to own a PH that is 10 years or less old.
for sure.
NO OS stated. by you.
both XP and VISTA have no Support now.
zero. and will get worse.
(cost of ownership huge and down time endless)
Aug 17, 2017 | Compaq Presario V2665us Notebook
The line is there because the connections to those pixels are bad so they end up uncommanded - fully open all the time. To fix it you will have to dismantle the lid and reseat the connectors to the LCD panel.
Dec 11, 2010 | Compaq Presario V2665us Notebook
Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Oct 01, 2009 | Dell Inspiron 9100 Notebook
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Two vertical lines on my compaq presario (M2000)
Try changing your screen desktop resolution to a different value. If you still have verticle lines, then try changing the color depth from 32bit to 24 or 16. If the problem remains your display adapter has completely failed. It has failed to compute column row addressing math.
Naturally, you would want to find and install the latest drivers for your display adapter with the hope that the failure is in the software driving the display adapter and not an onboard chip. If updating your drivers fails to resolve the issue you need to have service performed on your laptop. Most laptops have the display adapter soldered on the main circuit board and many shops are capable of replacing this chip set.
Yet, get a quote first as the cost might cause you to consider an upgrade into a laptop that has a display adapter that is Direct X 9c or Direct X 10 ready as that will run most of the new game titles coming out this year.
Let me know if you have any further need of assistance as you run through the above troubleshooting routine.
I do hope this has fixed ya!
Worldvet
May 16, 2008 | Compaq Presario M2000 Notebook
Two vertical lines on my compaq presario (M2000) laptop
Well, since the line disappear when the screen saver comes on, I"m led to believe that all the hardware side of the equation is OK. To put it simply, if there was a malfunction in the video (chances are) it would affect that too.
I would update (most likely available as nobody usually does this) the firmware for your video card. So identify the card EXACTLY, from documentation, or from the build list on the manuf. website, goto the manufacturer, say, ATI, and find the firmware there, where you will also find instructions to install it.
Then, just to be sure, I would update the video driver for Windows, in a similar manner to the instructions above.
If, despite all the above you still have a problem, then its time to get the computer serviced.
Good luck,
Erik.
Compaq Presario 5000 PC Desktop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
