Question about Whirlpool GB2SHDXTS Stainless Steel
Hello, Recently bought a new whirlpool 2273. It is frosting up at the back. The door is properly closed and I would be grateful if you could give me some idea of what could be wrong. Best regards Christina
Fridge working but freezer wont allow me to turn it down from 3 degrees c what can i do. it is an american whirlpool
Posted on Jul 31, 2009
I'm getting frost and ice build up on the bottom and back of the fridge compartment on my LG French door fridge.
To me This is on all Makes and models build up of frost means warmer humid air is entering into colder air this will cause a frost build up from entrance of warm air coming in so your looking at your air flow in all compartments of your ref,freezer so on.
blocked air will give false readings to sensors when compartment is asking for lower temp colder temp will be noticed.
bad or obstructed door seals door not closing properly
Follow your frost line it will point the way.
Jul 21, 2015 | LG Refrigerators
Model ED26SSXL 25.6 cu ft Trough that ice leaves ice bin to door dispenser frosts then ices up. I recently had it start to melt and the interior temp started to raise. Do I need a gasget or a seal? ...
It could need a seal or perhaps it not fully closing depending on what exactly is wrong will determine parts price.
To see if it's not fully closing,open the door and shine a flashlight in the outside the dispenser chute( the front part where the ice comes out) if you see light shining through it's not fully closing,if no light it needs seal/gasket
Gene
Jul 30, 2011 | Whirlpool Refrigerators
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Keeps giving error code 061
Hello sir; Did you recently replace new toner, if you did, please go back to check out does the door close right, otherwise you have to check the corona wire is broken?
Jan 04, 2010 | Canon CLC-700 Copier
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not cooling properly set all the way to coolest setting freezer seems to be cooling ok
check coils underneath may be dirty, if frost in frz. back wall then you have a defrost problem. make sure door was not left open (accidently). make sure door closing properly and gasket is sealing properly. check to make sure light turns off when door closed. hope this helps if not contact us with any additional info. needed. thank you for your time.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE # 8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair
EMAIL custmomerservice@allbrandsappliancerepair.com
Jul 11, 2008 | Whirlpool Refrigerators
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Frost on icemaker door
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Nov 21, 2007 | Refrigerators
Open Questions:
Whirlpool GB2SHDXTS Stainless Steel Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
