Question about Canon imageRUNNER 2270 Copier
I have an IR-3300 Model xerox machine. It was
I have an IR-3300 (Canon) Model xerox machine. It was showing low ink message on display so, I filled the toner. But now printing is very light & comes in shadow like Blurry. please solve my problem
  • Anonymous Mar 12, 2014
    error code 121 in ir canon xerox machine how to solve the problem and what is the problem? Please
  • 149 Answers
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
HOW TO XEROX MACHIN IR3300 MITER DOWN
Posted on Jan 18, 2013
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} CA 220 error Code
Toshiba e studio Model 232 what us this code for.
Posted on Sep 11, 2010
Canon ir 3300
it is related to zero detection.kindly check power supply at customer place(frequency)
Dec 04, 2013 | Office Equipment & Supplies
Canon ir 3300 machine error code 0064, plz suggest
CLEAN THE DUST & WASTAGE INK ON TRANSFER CARONA IN MACHINE & RESTART IT .
Dec 20, 2010 | Canon imageRUNNER 400S Copier
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
Feb 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
Canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Feb 13, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 2270 Copier Logo
868 people viewed this question
old marine
old marine
